EAGLE User Chat (English) How to change thickness of text?
  • Subscribers 179 subscribers
  • Views 1766 views
Somehow the text snapped to a thinner structure. It's proportional font
and I can't get it back to the fatter font. Right now I am just copying
old text (from before when it snapped for some reason), then change it
with the text tool. Is there a proper way to do it?
Regards, Joerg
    On 2008/May/14 10:02 PM, in article g0g5k7$eul$1@cheetah.cadsoft.de, "Joerg"
    Hi Joerg,
    Use the ratio property.  I think the formula is
    Stroke width = size * ratio
    In any case, increasing the ratio will make the stroke thicker.  It might be
    a case of the default ratio changing in the eagle.scr file?
    Cheers,
    James.
    James Morrison
    http://www.eagletoolkit.com
    Online EAGLE Dealer for US and Canada
    EAGLE Design Expert
    EAGLE Enterprise Toolkit
    Hi Joerg,
    That's just the point, it seems that with a proportional font changing
    the ratio does not do anything. The text remains skinny and hard to read
    on a printout.
    What worked was to close the file, close Eagle, open Eagle again, load
    file. Now it's back to normal. I still cannot change the thickness but
    at least it's back to standard thickness. Weird ...
    Regards, Joerg
    "gmail" domain blocked because of excessive spam.
    Use another domain or send PM.
    On 2008/May/15 1:20 PM, in article g0hrdg$hs3$1@cheetah.cadsoft.de, "Joerg"
    Hi Joerg,
    on a printout.
    Hi Joerg,
    Are you in the schematic editor (knowing how you use EAGLE I suspect this is
    the case).  In that case, I'm not sure.
    I have vector fonts always on so I'm not sure how proportional fonts
    influences this.  I would think the ratio parameter does the same thing but
    I don't know for sure.
    What version of EAGLE are you using?   Closing and opening the file should
    have no effect on this at all.
    James.
    James Morrison
    EAGLE Design Expert
    Hi Joerg,
    on a printout.
    Hi Joerg,
    Yes, schematic. If any of my clients wants an Eagle layout I'd give you
    a call and then send the stuff to Ontario image
    Vector fonts don't look very good when doing an initial presentation
    with just block diagrams.
    Version 4.16r2. It does have some weirdnesses to it that have been there
    in previous versions as well. For example, there are never any active
    libraries when starting up so "use *" must be typed in every time. Or
    sometimes it won't print. No error message, nothing. Then you have to
    restart or de-select and re-select the printer. Kind of like
    double-clutching on large trucks.
    Regards, Joerg
