EAGLE User Chat (English) beginer begging
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 882 views
beginer begging
http://www.zr5sdb.co.za/things/Projects/Dashboard%20Digital%20Voltmeter.pdf
Here is a great little project I'd love to START my Eagle work with. I
beleive I'll grow the project into several little jobs. But, I can't seem to
get started with Eagle!! I've downloaded the 5.0 but can't find my way
around the libraries and can't find any of the three ICs this project needs.
Might I ask one of the members of this group if you can get me started?
Thanks in advance
Bill Johnson
bill@billjohnson.net
    autodeskguest over 17 years ago in reply to autodeskguest
    futrtrubl schrieb:
    Ray Xu wrote:
    Hi, I'm new to this thing (not EAGLE).  It happened recently when I
    opened up my schematic and tried to add a part.  When the "add" dialog
    opened, there was nothing displayed.  I tried re-installing it (turned
    out instead of re-installing, I upgraded to the newer version), but
    that didn't help either.  I also noticed some strange things happening
    on my computer. Thanks in advance.
    Ray Xu
    rayxu@tx.rr.com
    At the initial control panel look at the library section and make sure
    the libraries have green dots next to them.
    Edward
    In case of windows: Check in control-panel/ options/ directories that
    the path is correct. In schematic type at the command line: USE *
    to load all libs listed ain the lbr-directory.
    Gruß
    Jörn
    Ray Xu wrote:
    Hi, I'm new to this thing (not EAGLE).  It happened recently when I opened
    up my schematic and tried to add a part.  When the "add" dialog opened,
    there was nothing displayed.  I tried re-installing it (turned out instead
    of re-installing, I upgraded to the newer version), but that didn't help
    either.  I also noticed some strange things happening on my computer.
    Thanks in advance.
    Ray Xu
    rayxu@tx.rr.com
    Edward
    Thanks in advance.
    Ray Xu
    rayxu@tx.rr.com
    Yes. DigiKey has them at reasonable prices. I drive an antique
    "International Harvester" Scout and am in a club with 20 or so more of the
    same model. My plan is to build "Oil" "Temp" "Fuel" and "Amp" guages which
    will fit into the original meter housings and then give them to the members
    of my club. Those will be quite a nice addition.
    I will investigate making my own. I can see I need time to figure this cad
    software out. It is attractive because it will let me move items physicaly
    on the board and keep the connections made. That will help me "fit" the
    boards in the small space.
    Thanks for you help.
    Bill
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:g12obh$5id$1@cheetah.cadsoft.de...
    Bill Johnson wrote:
    Sorry I was not more specific. The ICs are;
    LM340-T-5 (5vdc voltage regulator)
    NTE2054 or CA3162E
    NTE2032 or CA3161E (BCD Display Driver)
    Can you tell me what libraries these might already exist in?
    Bill
    It is quicker to make your own device as Bert suggested and any lib you
    find should be checked against the data sheet.
    But before you get too involved with that project can you find the IC's in
    small or required quantities.
    A job like that can be done with a pic microcontroller and some software
    for a lot less hardware cost. You just have to have the volume to pay for
    the software time.
    Paul R.
    NTE2054 or CA3162E
    Bill
    in small or required quantities.
    for the software time.
    Paul R.
    NTE2054 or CA3162E
    Bill
    "Bill Johnson" <bill@billjohnson.net> wrote in message
    news:g0ssbg$lgh$1@cheetah.cadsoft.de...
    to get started with Eagle!! I've downloaded the 5.0 but can't find my way
    needs.
    Thanks in advance
    Bill Johnson
    seem to get started with Eagle!! I've downloaded the 5.0 but can't
    find my way around the libraries and can't find any of the three ICs
    this project needs.
    started?
    Thanks in advance
    Bill Johnson
    Finding parts in the Eagle libraries can be difficult if you're new to Eagle
    (and sometimes even if you're not).  Your U1 sounds like a standard 5V
    regulator in a TO-220 package.  Look for LM340 or 7805.
    Your U2 and U3 are part numbers I've never heard of.  You may end up having
    to make your own parts.  It's really not that hard, but you'll have to take
    some time to read the manual and understand the process.  Since these chips
    have standard DIP footprints, you can use an existing DIP Package from an
    existing library, make up your own schematic Symbol, and then create your
    own Device using the Symbol and Package, and Connect the respective pins to
    the pads.
    Bert Menkveld
    "Bill Johnson" <bill@billjohnson.net> schrieb im Newsbeitrag
    needs.
    Thanks in advance
    Bill Johnson
    Please, have a look into the manual and the tutorials first.
    T.
