EAGLE User Chat (English) Do not trust the Farnell Eagle Libraries!!!
  • Views 666 views
crosland
crosland over 13 years ago
I am now going to have to respin a PCB due to incorrect pinout on the simplest of devices, ZXCT1107 in a SOT23 package.
OK, it's my fault for not checking, but I expect better from Farnell.
Andrew
    autodeskguest over 13 years ago in reply to autodeskguest
    James Morrison wrote:
    Andrew Crosland wrote on Fri, 09 August 2013 15:14
    It's not in the standard libraries.I referred to the Farnell
    libraries.
    It's in their Diodes Inc library.
    Hi Andrew,
    It sucks when you run into something like this.  My rule of thumb from
    many years of experience is "DO NOT TRUST ANYONE'S LIBRARIES BUT MINE".
    James
    For a really good time, use a standard library part that's been changed
    since the last library release, with no change notice.
    That's why James is SO right. The best hour or two you will ever spend on
    the Eagle learning curve is the hour or two spent learning how to properly
    make your own libraries, even if they're nothing more than carefully checked
    cut-n-paste parts from existing Eagle libraries. At a previous employer,
    they used a fancy library that cost five figures with their PADS layout
    package, and it was still a mess of inaccurate footprints and pin
    assignments. I've seen library parts DIRECT FROM THE IC MANUFACTURER that
    didn't match the datasheet, or the part. In the end, the only one who cares
    about your board and your money is you. I've learned that lesson myself the
    hard way.
    Bob
    autodeskguest over 13 years ago in reply to crosland
    libraries.
    Hi Andrew,
    It sucks when you run into something like this.  My rule of thumb from many
    Our internal process is that any device we use MUST come from our library.
    We sometimes will copy things in from publicly available libraries but then
    we have a whole checklist of things that we go through to make sure they
    are right.  Often times it's easier to just create them from scratch.
    This isn't just an EAGLE issue either, we treat Altium exactly the same
    way.  Engineers should be skeptical.  At the end of the day, if the board
    doesn't work, people don't really care why.  You were supposed to create a
    board that worked and it didn't.  That is usually where the conversation
    ends.
    For hobbyists, it's a bit different.  But with limited $$$ you'll want to
    make sure what you send out is right.  So the same rule should really
    apply.
    Cheers,
    James
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
  • crosland
    crosland over 13 years ago in reply to shabaz
    It's not in the standard libraries.I referred to the Farnell libraries. It's in their Diodes Inc library.
    Andrew
    shabaz over 13 years ago
    Hi Andrew,
    I don't see it as part of the standard libraries, which URL did you use to download it?
    EDIT:
    I see it on the site; you're right, it should be corrected.
    Personally I just make my own parts always (apart from Rs and Cs).
