EAGLE User Chat (English) Make a hotkey to switch layers & slow follow-me
  • Views 398 views
I am fairly new to Eagle CAD and the forums here.  Probably an easy
one.  What is the command to switch layers when manually routing?  I
know I can click on the select layer box in the top left, but I would
like to map a hotkey.  I figure it is something like "change layer route
top" or something.  I tried a few combinations with no luck.
Another thing I noticed, is that the follow-me routing is too slow to
even use.  Is it just my machine, or do other people experience this?  I
am running windows 8 on a dell latitude e6430.  When I click the
"follow-me (from one side)", and start to route, the entire program
freezes until I switch back to manual routing and grab a cup of coffee.
It's also a fairly busy design which I am sure is a factor.
Eric
http://www.element14.com/community/message/86594#86594
    If you just wish to switch between the top and bottom layers, click the
    centre mouse button.
    HTH
    Warren
    Try the "Alias" function - for more details see the online help. You can
    define aliases for: Display (layers for sch & brd seperatly), Grid & Window.
    Make your settings first then use the RMB at the appropriate button & give
    it a name. Now you can use it (max. 256 aliases). It's possible to edit,
    rename or delete an alias with the RMB on the alias. I made a lot of aliases
    for my work & they are very useful but in german image
    r
