EAGLE User Chat (English) Using *.ln4 and *.pd4 components with Board Layour
  • Subscribers 177 subscribers
  • Views 246 views
Is there a way to import *.ln4 or *.pd4 components into the board layout
tool?
    tool?
    If I'm not mistaken, those are from Mentor Graphics PADS. In PADS Layout
    (or PADS Logic, for that matter) you can go to the Help menu, then
    Interface Specifications -> Library ASCII Specification. That will open
    a PDF document describing the library file spec. I'm only loosely
    familiar with ULP, but you could probably write a ULP or even a Basic
    script within PADS itself to generate an EAGLE Script, which would
    re-create those parts within EAGLE.
