EAGLE User Chat (English) mils or mm grid
  • Subscribers 177 subscribers
  • Views 322 views
mils or mm grid
Hello, new to the group. Been having pretty good success routing boards with
eagle on a .5mm grid.
Are there any advantages to using a 10mils grid?
My designs are analog, utilizing smt (SOIC, 805 passives) and thru hole
parts (pots, transformers, diodes etc..).
Eventually I would like to use pick and place for the SMT parts, and
complete assembly at my shop.
Any insight will be greatly appreciated.
Tony
    boards with eagle on a .5mm grid.
    hole parts (pots, transformers, diodes etc..).
    Tony
    I don't think it matters much what routing grid you use.  Whatever grid you
    choose, there will always be components with off-grid pads.
    Personally I'm used to a 25 mil grid, which works neatly for DIP packages
    and standard through-hole passives, and some SMT packages (like SOIC).
    However, many packages still end up with off-gird pads.
    Bert Menkveld
