EAGLE User Chat (English) Top/bottom component placement
  • Views 2088 views
I'd like to make a double-sided PCB with through-hole components and
circuit traces on both sides but am a little confused about the
top/bottom thing:
1) which side am I looking at in Eagle?
My guess is that I look "down" on the top side of the PCB and that the
components face upwards -correct?
2) How do I place components at the bottom side?
I've read that the "mirror" command does this, but shouldn't the
component color change as well, to indicate t's on the other side? Here
they're all white/green regardless of mirroring or not but I see the pin
numbers change. It's a little confusing to know which side the physical
component is located on.
    e14 Contributor over 10 years ago in reply to autodeskguest
    The color change happens on surface mount parts. Through hole components
    stay the same color, the way you can tell is by looking at the text.
    Additionally, if you have the pad names displayed you'll see that their
    locations change due to being mounted on the bottom.
    The color change happens for through hole components too.
    You can change the colors at the display-menu.
    For this example look at tplace / bplace.
    Set a color for bplace that is not the same color as tplace.
    autodeskguest over 11 years ago in reply to autodeskguest
    On 10/08/2015 17:58, Jorge Garcia wrote:
    I see. I assume it's a good idea to print out the bottom and top sides
    of the PCB on paper to check before actually ordering the PCB from a
    board house. Are there any good guides on how to do that?
    Hi Logyx,
    Yes that would be a good idea. Just do a File > Print, in the simplest
    case you won't have to calibrate your printer and it will print to scale.
    If you do have to calibrate then that procedure is pretty simple.
    Much appreciated useful info. Thanks Jorge!
    L.
    Hi Logyx,
    1. Print out a rectangular board and make sure you know the size of it.
    2. With calipers or other accurate measurement instrument, measure the
    bottom edge of the board. Compare that measurement to what you specified
    in EAGLE. Obtain the following ratio:
    Specified in EAGLE/ What I measured.
    3. Repeat with the right or left edge of the rectangle obtain the ratio.
    4. Go file > print on the bottom left you'll see a section labeled
    calibrate. Enter the ratios in the appropriate spots and try printing
    the rectangle to confirm that your corrections worked.
    5. If things got worse, then use the reciprocal of the ratios and try again.
    hth,
    Jorge Garcia
    This is correct, imagine you have XRAY vision and your staring at the
    top of the board.
    Thanks for clearing that up.
    L.
    top of the board.
    Hth,
    Jorge Garcia
