EAGLE User Chat (English) are libraries posted online compatible with versions 4.1 and 5?
  • Replies 9 replies
  • Subscribers 181 subscribers
  • Views 1063 views
Are the libraries posted online compatible with versions 4.1 and 5?
    On 2008/Jun/21 4:31 PM, in article g3jofb$f4$1@cheetah.cadsoft.de, "Talal
    All libraries are readable with the latest version of EAGLE, in this case 5.
    EAGLE 4.1 would only be able to read libraries that were posted with EAGLE
    4.1 or before.  The descriptions do not generally include this information
    so its a bit hit or miss from my experience.  You could sort of tell from
    the date posted, but that's not 100%.
    Cheers,
    James.
    ~  James Morrison  ~~~  Stratford Digital  ~
    ~  email:  sales@eagletoolkit.com          ~
    ~  fax:    888.701.8097                    ~
    ~  web:    http://www.eagletoolkit.com     ~
    ~  Online EAGLE Dealer for US and Canada   ~
    ~  EAGLE Design Experts                    ~
    ~  EAGLE Enterprise Toolkit                ~
    BTW, only post to one newsgroup.  I didn't see the cross-posting until my
    response showed up in both.
    Cheers,
    James.
    Former Member over 17 years ago
    As I understand it the library format is different between the two.
    Version 5.0 can read the old and the new format, V4.x only the old format.
    In practice, if you create an object with V4.x it will be usable with
    both versions. If you create it with V5 it will be available only to
    version 5 users.
    Markus
  • streichre
    streichre over 17 years ago
    Is there a method for converting newer libraries to older versions?  Maybe a
    utility or a copy and paste method?
    Thanks for any help,
    Charlie
    "James Morrison" <spam2@stratforddigital.ca> wrote in message
    news:C482E41F.61A1C%spam2@stratforddigital.ca...
    5.
    Cheers,
    James.
    Former Member over 17 years ago in reply to streichre
    I'm also looking for a utility or a way to convert back from 5.x to
    4.1x, something that runs on OS X would be nice...
    I was testing the freeware version of 5.1, evaluating it under OS X and
    I loaded my custom 4.16 library into 5.1 and must have hit save and now
    4.16 won't load the library any more...
    Anyone know how to get out of this mess other than by upgrading or
    recreating all the footprints??
    On 2008-07-15 01:21:55 +0930, "Jim Bob" <cdblues2000@yahoo.com> said:
    Charlie
    5.
    Cheers,
    James.
    autodeskguest over 17 years ago in reply to Former Member
    Somehow my first post vanished while typing, sorry if it shows up as well.
    Anyhow, try this: Place all the parts from your custom library onto a
    schematic, store in 4.1-compatible (I sure hope 5.0 can do this ...),
    open in 4.1, then execute the ULP that creates a custom library from all
    the parts used in that schematic. IIRC the ULP is called somethin g like
    exp-project-lbr.ulp
    Now rename that library to what it used to be. Oh, and this time maybe
    run a backup before trying any file shuffling image
    Regards, Joerg
    One more hint, from Lewin on the embedded NG: See if Eagle didn't write
    *.l#n backup libraries when you accidentally saved. The old one might
    still be among those.
    Regards, Joerg
    Former Member over 17 years ago in reply to autodeskguest
    On 2008-09-01 10:30:55 +0930, Joerg
    Thanks for the ideas but they didn't work for me.
    1) Eagle 5.x doesn't seem to have the facility to save schematics in
    the old format (at least I couldn't find how to do it) sinking your
    first idea
    2) None of the backup libraries  (*.l#n files) survived either, I guess
    I am just a nervous saver and have gotten into the habit of saving
    often whether I need to or not!
    Normally this stops you from getting into trouble with corrupted files!
    An upgrade it is then for me.....
    A note to CadSoft - it might have been nice to have a message box flash
    up warning the user about incompatibility issues when saving a
    schematic/board/library generated from an old version within the new
    version of EAGLE....
    and I loaded my custom 4.16 library into 5.1 and must have hit save
    and now 4.16 won't load the library any more...
    write *.l#n backup libraries when you accidentally saved. The old one
    might still be among those.
    1) Eagle 5.x doesn't seem to have the facility to save schematics in the
    old format (at least I couldn't find how to do it) sinking your first idea
    I am just a nervous saver and have gotten into the habit of saving often
    If you want to avoid the upgrade (personally I'm not convinced about v5 yet)
    then if you have v4 designs that use your custom libs then you can at least
    extract part of your library from these designs using the exp-project-lbr
    ulp.  Depending on how extensive your lib was this may be a route to
    recovering most of it.
    cheers
    David
