EAGLE User Chat (English) Copying circles to both sides of the PCB
  • Subscribers 187 subscribers
  • Views 697 views
I'm working on a double-sided PCB and for sturdy mounting I thought it
would be a good idea to have relatively wide copper-filled circles where
I drill a hole inside for the screws.
I used the "Circle" tool for this.
I would think having them on both sides would make the board even
sturdier, so how do I copy a circle from one side of the PCB, then place
it on the other side at the exact same location?
    autodeskguest over 10 years ago in reply to autodeskguest
    Am 07.06.2016 um 11:34 schrieb Robert von Knobloch:
    Hi, I am using V4.7.0 as freeware (I am now retired).
    I make PCBS using laserjet output and an etch tank.
    Top side copper for SMDs.
    When a component requires a drilled hole, I have tried to assist
    drilling by placing a circle with a small centre hole in top copper.
    Printing this shows correctly in the print preview, but the printed
    output has removed these 'drill helpers' totally.
    Any ideas?
    Cheers,
    Bob
    Do you mean the "drill-aid.ulp" that places little circles on layer 116?
    You must display layer 116 of course image
    Joern Paschedag
    Any ideas?
    Cheers,
    Bob
    autodeskguest over 11 years ago in reply to autodeskguest
    Is there any reason you couldn't use a VIA for this? Vias can be made
    pretty large and I think it's simpler since you automatically get the
    copper on both sides.
    You're absolutely right. Vias seem like the logical choice and solves
    the alignment issue as well. Thanks!
    Hi Logyx,
    hth,
    Jorge Garcia
