EAGLE User Chat (English) Printing 'feature'
  • Subscribers 187 subscribers
  • Views 521 views
Printing 'feature'
I have found a 'feature' while trying to print a layout.
In this layout, I use the "trestrict" layer.
Printing allows the option 'solid' to be selected or not.
If 'solid' is selected (the default), then all is OK.
If 'solid' is deselected (to not obscure some detail) then my HP
laserjet appears to swallow the print job without trace.
I have Eagle version 6.5 installed on OpenSuse Linux 12.1, using CUPS,
printing directly (over a TCP socket) to an HP Laserjet CP3525 colour laser.
CUPS insists that the files have printed (data was sent), but no paper
or error or warning appears on either the printer or in CUPS, just no
printout.
I imagine that this is a printer problem (it doesn't like the 'hashed'
pattern of trestrict), rather than Eagle, but it might be helpful for
anyone suffering similar problems.
I imagine that other HP Laserjets are also affected.
Cheers,
Bob von Knobloch.
    autodeskguest over 13 years ago in reply to autodeskguest
    This could be the 'banknote printing prevention' mechanism that many
    laser color printers now have, mandatory scanning for the fine hashed
    patterns as banknotes typically have. Another government intrusion in IT.
    R.
    laser.
    printout.
    Cheers,
    Bob von Knobloch.
    In the CUPS config file (usually /etc/cups/cupsd.conf) you can change the
    LogLevel parameter to 'debug', restart CUPS, and it will then dump the
    entire print job history of any future print jobs to its log file
    (/var/log/cups/error_log or wherever SUSE puts it). If CUPS is failing
    silently, examining these detailed logs will typically show where things
    went wrong. Don't forget to revert the LogLevel back to the default
    (typically 'warn') when done to avoid massive print logs.
    Another option is to print to PDF and then, if it actually generated a
    PDF,
    just output the PDF file directly to the printer using lpr.
    If you've already tried both of those steps, CUPS doesn't report any
    problems, and the printer still doesn't print, then yes, you've run
    across a
    printer bug. I've occasionally run across them on my Brother laser
    printer's
    built-in postscript interpreter as well.
    Bob Johnson
    No Bob, it's the printer.
    I can capture the Postscript file on the ethernet cable, as it is sent
    to the printer. Just no output.
    Chees,
    Bob
    laser.
    printout.
    Cheers,
    Bob von Knobloch.
    Another option is to print to PDF and then, if it actually generated a PDF,
    problems, and the printer still doesn't print, then yes, you've run across a
    printer bug. I've occasionally run across them on my Brother laser printer's
    Bob Johnson
    Chees,
    Bob
    laser.
    printout.
    Cheers,
    Bob von Knobloch.
    Bob Johnson
