EAGLE User Chat (English) Merging two different nets
  • Subscribers 189 subscribers
  • Views 1813 views
I'm relatively new to Eagle. I want thick 28 mil traces going to my 3 amp components, with thinner 16 mil traces brancing off to my 500 ma components. With Eagle 5, I believe merging two nets like this required the use of a jumper library and dismissing some DRC errors. Is there a better workflow in Eagle 6? Thanks for the help.
    autodeskguest over 12 years ago in reply to e14 Contributor
    Jeremy Williams wrote:
    CadSoft Guest wrote:
    Yes to the first, no to the second. If the net has an associated
    class, the
    class may enforce some trace width restrictions, but otherwise Eagle
    has no
    problem with different trace widths on different segments of the same
    net.
    Hm... Maybe I need to merge net classes then. I am relying on freeroute
    to lay my traces, and as far as I can tell there's no way to assign
    trace widths on the schematic view without uses net classes. Am I wrong?
    http://www.element14.com/community/message/88933#88933
    Perhaps not. I've never used freeroute; if it requires net classes to set
    trace width that could be an issue.
    Bob
    e14 Contributor over 12 years ago in reply to autodeskguest
    Yes to the first, no to the second. If the net has an associated class, the
    class may enforce some trace width restrictions, but otherwise Eagle has no
    problem with different trace widths on different segments of the same net.
    Hm... How do you have a wire or net without a class? It seems that every new wire I draw gets the default class automatically, unless it joins a different one.
    If you name them the same, one has to join the other "net" and adopt its
    trace width. Right?
    http://www.element14.com/community/message/88867#88867
    e14 Contributor over 12 years ago in reply to fritzz
    If you name them the same, one has to join the other "net" and adopt its trace width. Right?
  • fritzz
    fritzz over 12 years ago
    Maybe I'm completely wrong, but don't you just name them the same to merge?
