EAGLE User Chat (English) where can I get a "PCB spark gap" device?
  • Subscribers 187 subscribers
  • Views 1462 views
Hi!
I want to add PCB spark gaps to my project in order to protect against
ESD (also add varistors, etc).
I've seen an example on this site:
http://www.airborn.com.au/method/sparkgap.html
Have anyone used anything similar?
Are there any device in any library available for eagle?
Thanks!
    Logicnibble schrieb:
    When you speak about spark gaps as components, are you referring to the
    GDT (gas discharge tube)?
    Exactly.
    However, since they are large, expensive and somewhat exotic, I prefer
    other ways of protection whenever possible (until now, this means
    "always" image ).
    Tilmann
    If you really want to use such, simply draw them they way you like.
    However, such "spark gaps" have been extensively discussed - and
    opinions on them range from "better than nothing" to "pure nonsense".
    The problems are:
    - You need some minimum distance to avoid unwanted shorts during PCB
      production;
    - The PCB production process always has some tolerances - taking these
      into account you finally get gap lengths that vary at about 1:3 or
      even 1:4.
    - Given these large tolerances, you can never predict the sparking
      voltage by any means, or to a tolerable voltage.
    - Additionally, since you need to leave the contacts uncovered from
      solder stop mask, you get environmental influence which further
      increases tolerances, regarding to spark ignition voltage.
    - Finally, dirt, humidity and other residues will be collected on the
      blank surfaces and eventually raise more serious problems than they
      were intended to protect against.
    My personal conclusion: They are not worth the time to draw them. If you
    need spark gaps, get them as components.
    Tilmann
    Thanks Tilmann!
    I guess you're right, it's going to be a pain in the neck with so many
    uncontrollable events...
    The problems are:
      production;
      even 1:4.
    Tilmann
