EAGLE User Chat (English) keepout problem on pac
  • Subscribers 187 subscribers
  • Views 294 views
I am creating an overlay button landing zone, and am creating a pattern on the top layer attached to pads, however the keepout on the pad throws a drc error where I need it to make contact with the landing pattern. does anyone know how to fix this?
TIA
Steve
    autodeskguest over 12 years ago
    steve martins wrote on Fri, 27 September 2013 05:28
    pattern
    throws
    Are you trying to create a component keepout or a copper keepout?
    Copper keepout is layer 41 (tRestrict) where as the component keepout would
    be layer 39 (tKeepout).  Any copper inside a tRestrict area will cause a
    DRC error.  For a component keepout, use tKeepout and any place where
    objects on that layer overlap you'll get a DRC error--so every component
    needs to have that defined for it.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
