EAGLE User Chat (English) Ver 5.1.0 SET Question
  • Replies 13 replies
  • Subscribers 179 subscribers
  • Views 1385 views
Former Member over 17 years ago
I have been using Eagle Pro versions for many years.  As part of an effort
to upgrade to Ver 5.1.0, I have run across an error message for which I
cannot find an answer.
"Error: Too many values for menu!"  while trying to use set drill_menu in
eagle.scr.
Clearly I have tried to include too many drill values, and I could delete
values until I no longer get the error, but it would be interesting to know
if the value is documented anywhere.  Does anyone know the value or can
provide a reference?
Steve.
  • Richard_H
    Richard_H over 17 years ago
    eagle.scr.
    Steve.
    It is allowed to have a maximum of 16 values. See also the help
    for the SET command.
    Richard Hammerl
    effort to upgrade to Ver 5.1.0, I have run across an error message
    for which I cannot find an answer.
    drill_menu in eagle.scr.
    delete values until I no longer get the error, but it would be
    interesting to know if the value is documented anywhere.  Does
    anyone know the value or can provide a reference?
    Steve.
    Thanks Richard.
    Steve
    effort to upgrade to Ver 5.1.0, I have run across an error message for
    in eagle.scr.
    interesting to know if the value is documented anywhere.  Does anyone
    Steve.
    I am generating gerbers for a PCB with 18 drill values, and all of the
    drills appear as pinpoints in the gerbers, is there only 16 drill values
    allowed in the .drl file?
    cheers,
    Jamie
    Steve.
    I removed some components until I have only 14 drills used, and now the
    gerbers are generated correctly.  I guess I have been pushing the limits
    of eagle too much lately image  Reached maximum schematic size limits and
    also drill count limits image
    cheers,
    Jamie
    cheers,
    Jamie
  • Richard_H
    Steve.
    cheers,
    Jamie
    There is no limit for the number of different drill diameters
    for generating manufacturing data. Are sure you used the EXCELLON
    device with the layers Drills and Holes active.
    You talked about Gerbers and this is not the same as drill data......
    Richard Hammerl
    Steve.
    cheers,
    Jamie
    Yes I first run drillcfg.ulp, then run excellon.cam, then gerb-274x.cam
    I've done several tests with simple boards with just vias, and still
    notice this error.  Perhaps I am doing something wrong, but I have made
    quite a few PCB's with eagle before that didn't have this problem.
    cheers,
    Jamie
  • Richard_H
    an effort to upgrade to Ver 5.1.0, I have run across an error
    message for which I cannot find an answer.
    Steve.
    values
    cheers,
    Jamie
    cheers,
    Jamie
    Sorry, I can't reproduce this.
    I made a board with 25 vias with different drill diameters. Each
    diameter appears in the rack file and is contained in the excellon
    file.
    I tried this with the rack file generated by drillcfg.ulp and the
    EXCELLON_RACK device and a second attempt with the EXCELLON device
    that writes the drill table into the excellon file.
    Both works fine.
    Richard Hammerl
    could delete values until I no longer get the error, but it would
    be interesting to know if the value is documented anywhere.  Does
    Steve.
    values
    limits
    cheers,
    Jamie
    cheers,
    Jamie
    file.
    Both works fine.
    Please try running gerb274x.cam after you run excellon.cam, this
    is where I noticed the problem, in the gerber files when I load them
    into GC-PREVUE.  I can send you my test brd file if you like that
    produces the faulty gerbers.
    cheers,
    Jamie
  • Richard_H
    would be interesting to know if the value is documented
    anywhere.  Does anyone know the value or can provide a reference?
    Steve.
    the
    values
    the
    limits
    cheers,
    Jamie
    cheers,
    Jamie
    file.
    Both works fine.
    please send me the files....
    Richard Hammerl
    of an effort to upgrade to Ver 5.1.0, I have run across an
    error message for which I cannot find an answer.
    Steve.
    of the
    values
    now the
    limits
    and
    cheers,
    Jamie
    cheers,
    Jamie
    file.
    Both works fine.
    I found out what the problem was while I was getting some files ready to
    send, its that the maximum allowable drill size is 0.236" or 0.6cm.  If
    the drill size is increased above this size then the drd file will be
    incorrect.  I tested this in version 4.16 and version 5.0.0.
    Some of my components have holes that are larger than 0.236", so I'm not
    sure the best way to get around this.
    cheers,
    Jamie
