EAGLE User Chat (English) BGA and High Speed Board
  • Subscribers 177 subscribers
  • Views 277 views
Hi
I would like to have some feedback of your experiences with the design
of complex boards that use BGA and have an High speed Address/Data Bus.
For example a system of :
          100Mhz Bus Speed
          32 bit Data Width
          14 bit Address Width
          Processor (BGA) +
          2 SDRAM(TSOP54) +
          FLASH(TSOP48)
Of corse I speak about handly routing with Eagle.
Does some one do that before?
Does any one have some special techniques and/or tools to easly do this job?
What about the placement strategy of the placement?
What is the traces width for a 0.8 mm pitch BGA?
What about respecting the traces lenght matching of the bus signal?
How to deal with accordion traces?
Do you think it's crazy to make a complicated ulp that help for
interactive routing?
There's a lot of questions but I will not charge you a lot.
Thank's in advance
BR
Abdallah MEZITI
    abdAllah Meziti wrote:
    Hi
    of complex boards
    I have no experience of such multipin components, but...
    Move them around in Eagle until it looks good.
    (see the airwires)
    Of course you need understanding of length matching data/clocking lines
    Eagle autorouter is speedy and i often test the placement by running it
    shortly, ripping up, move components, retry.  For finishing, I often end
    up roputing it all manually however, but see below.
    Ask your manufacturer how thin traces and isolation distances he can use
    at what cost levels, if he can do micro vias, sizes of vias etc...
    (not my cup of tea)
    Absolutely, use what exist;
    You can export to the java program http://freerouting.net/ and back to
    eagle.
    That said of course set up GND plane, maybe power plane and route power
    and decoupling manually, maybe clocking, oscillators and such.
    Then save that, before autorouting.
