EAGLE User Chat (English) freerouting.net
  • Replies 7 replies
  • Subscribers 177 subscribers
  • Views 662 views
freerouting.net
Has anybody any reports on using this seemingly free/ awesome product with
eagle?
http://freerouting.net/
Tony
    eagle?
    Tony
    Works great.  Have done many boards that I have only routed the critical
      traces.  The trick is to insure that you modify the line in the ulp to
    convert to dsn
    int preprotect = 1;
    This will insure that if you preroute some traces they will be  left
    alone.     Just let it finish because the final passes are to optimize.
       Have done about 20 boards and have had great luck with some really
    tough routing problems.
    Tom
    "Tom C." <tckc98@netzero.com> wrote in message
    news:g6rdpq$gbd$1@cheetah.cadsoft.de...
    with eagle?
    Tony
    convert to dsn
    int preprotect = 1;
    Have done about 20 boards and have had great luck with some really tough
    routing problems.
    Tom
    It sort of blows my mind that it exist.
    What did you think of the push shove style manual routing? I hope eagle adds
    that someday.
    Tony
    eagle?
    Tony
    I have just lost an hour trying to get this to work. All I get is a
    message telling me the virtual machine won't start. I have installed the
    updated JVM; removed all old Java installs and reinstalled the new JRE;
    restarted the machine. All to no avail.
    Other JNLP packaged stuff seems to run but not this and no sensible
    error message.
    Anyone got any ideas?
    Pete
    "Peter Harrison" <peter.harrison@hrlicron.net> wrote in message
    news:g6smjm$8ed$1@cheetah.cadsoft.de...
    with eagle?
    Tony
    Other JNLP packaged stuff seems to run but not this and no sensible error
    message.
    Pete
    I am getting that same message on my Mac OS 10.3.9 computer. I'll try it on
    my XP computer today and let you know.
    Tony
    with eagle?
    Tony
    message.
    Pete
    Tony
    Works fine on Ubuntu 7.10 if you install Java 6 from the repositories.
    http://www.ubuntu.com/
    Paul R.
    Tom C. wrote:
    with eagle?
    Tony
    convert to dsn
    int preprotect = 1;
    Tom
    Seems to be a very nice product.
    Is there a way to select only the bottom layer for routing?
    Jesse
    J. op den Brouw wrote:
    Tom C. wrote:
    with eagle?
    Tony
    critical  traces.  The trick is to insure that you modify the line in
    the ulp to convert to dsn
    int preprotect = 1;
    optimize.   Have done about 20 boards and have had great luck with
    some really tough routing problems.
    Tom
    Jesse
    Yes, certainly. Simply deselect the top layer in Freeroute. I have used
    it for many small single sided boards. I usually make a few test runs
    and then move the components in Eagle so that tight spots disappear. The
    'push and shove' manual routing works great as well. If the autorouter
    does not manage, just delete a few routes, draw some connections by
    hand, and start the autorouter again. No need to route 'nicely' by hand,
    the autorouter cleanup phase takes care of that.
    Robert
