EAGLE User Chat (English) Ripup via, left over hatching?
  • Subscribers 187 subscribers
  • Views 274 views
As shown in the attached image, I can't seem to get rid of this hatching when removing a via. This was done before I knew the correct process for creating vias (draw layer1 trace, place via, continue on other layer2). These were done manually then renamed using "name" to connect the two traces. Even if I move the via, this hatching doesn't move, nor is it selectable. I've tried ratsnest'ing and it doesn't disappear. First of all, what is it? And second, how can I get rid of it?
Thanks!
    autodeskguest over 12 years ago
    Op Sun, 20 Oct 2013 18:49:49 +0200 schreef Drew Harris
    <noreply-216602@element14.com>:
    Thanks!
    Can't see you image in the newsgroups, but it is likely the 'error
    indicators' leftover from running a DRC.
    Type 'ERRORS CLEAR' in the command line and they should be gone.
    HTH
    Richard
