EAGLE User Chat (English) Single Side with wire link top layer ?
  • Subscribers 177 subscribers
  • Views 998 views
Is there a way to get Eagle to auto route as a single sided pcb (one
layer) with straight wire links as the "top layer" ?
I can get single sided board easily enough by setting top layer to "N/A"
I have tried fiddling with the routing parameters to try and get the top
layer as straights only, but need to minimize no of "track" on the top
layer.
The closest that I can come at this point is to auto route single layer,
then manually go and add tracks and vias for the wire links - a painful
process.
Using 4.16r2.
Thanks in advance
Anton Schoultz
    On Wed, 06 Aug 2008 19:26:52 +0200, Anton Schoultz
    layer.
    process.
    I am no expert but how about a zero-ohm resistor.  Eagle is happy and
    you put anything in the resulting board, including a hunk of wire.
    layer.
    process.
    Using 4.16r2.
    Thanks in advance
    Anton Schoultz
    Generally, on all but the simplest circuits, to produce a board with good
    immunity and emissions specs on a single sided layout requires very careful
    routing, and I would never let an autorouter near a single (or double sided)
    layout.  Routing of gnd/current return traces is always critical for single
    and double sided layouts.
    Every time I see someone looking to autoroute single and double sided PCB's
    I really feel they are missing out on actually learning anything or showing
    any understanding about good PCB layout.
    Having said that I'd recommend your first approach. Route as a double sided
    board with a high cost factor for the top (wire link) layer.
    Just because the autorouter puts a bend in the wire doesn't mean you have
    to.  There is always a straight line between the start and end points- or do
    you only want wires in the vertical and horizontal planes?  What is you
    criteria for only having straight lines on the top layer and why is it so
    important?
    cheers
    David
    top layer as straights only, but need to minimize no of "track" on the
    top layer.
    layer, then manually go and add tracks and vias for the wire links - a
    painful process.
    Using 4.16r2.
    Thanks in advance
    Anton Schoultz
    good immunity and emissions specs on a single sided layout requires very
    careful routing, and I would never let an autorouter near a single (or
    double sided) layout.  Routing of gnd/current return traces is always
    critical for single and double sided layouts.
    PCB's I really feel they are missing out on actually learning anything
    or showing any understanding about good PCB layout.
    sided board with a high cost factor for the top (wire link) layer.
    have to.  There is always a straight line between the start and end
    points- or do you only want wires in the vertical and horizontal
    planes?  What is you criteria for only having straight lines on the top
    layer and why is it so important?
    cheers
    David
    Hi David
    I thought Id like to pop in to this topic even though you have said it all.
    But to clearify why some people wants to make single sided boards is the
    simple fact that many hobbyist starts right here either by using
    euroboards or by etching ones own single sided board. Then one can not
    always ensure that one is able to route everything on one single side,
    but one would be required to do some strapping. If the auto router can
    give you the least amount of strapping possible (with straight lines
    which looks most pretty on the component side) then why not.
    For hobyist and some prototype makers and "small budget indeed" hobyist
    the best gift would actually be an autorouter and grid setup feature
    which simulates an euroboard. Like it or not. For companies or advance
    hobyist it might look like a vast but the need is still there for
    someone. Thats was where I started my self before gradually the
    knowledge and selftrust grown to be able to make professional looking
    products/layouts.
    I do not think they are "missing out" on the learning process, but
    sometimes one need to learn to walk (i.e. make some electronics that
    works) before one can climb the mountains (i.e. making perfect PCB
    layouts with perfect electronics). And sometimes the first steps takes
    longer time to learn than learning to run when you already knows how to
    walk.
    I am sure Anton know aboute these facts that for a good comercial
    product every inch of your schematics and PCB must have been
    investigated several times to ensure the best possible product but
    sometimes "quick and dirty" is more than you ask for.
    breg
    Vidar(Z)
    the top layer.
    a painful process.
    Using 4.16r2.
    Thanks in advance
    Anton Schoultz
    very careful routing, and I would never let an autorouter near a
    single (or double sided) layout.  Routing of gnd/current return traces
    is always critical for single and double sided layouts.
    top layer and why is it so important?
    cheers
    David
    Hi David
    products/layouts.
    walk.
    breg
    Vidar(Z)
    Vidar hit the nail on the head. I am decidedly in the "budget hobbyist"
    category. image The board that I want to put together is a prototyping
    board for a PIC processor - with some additional circuitry such as shift
    register, bcd->7seg, and 1-of-10 low so that I can experiment with
    driving LCD module using two or three I/O lines (and shift register) to
    play with driving an 8 digit mux'd numeric led  display etc. later I'd
    like to set up some proto-pcb for experiments with I2C etc. I have had
    PCB made which are laid out like a breadboard - a little better than
    using veroboard. image I DO appreciate that some PCBs need a lot more care
    and attention, to the extend of ensuring that all data paths are the
    same length to prevent jitter at high clock frequencies etc - but I'm
    not building a motherboard for a ?GHz cpu. While the insides of the pic
    run at 6Mhz, the outside/real world signals will be in the order of KHz.
    An auto-router that can do a half way decent routing job which minimizes
    the wire straps (both length and number of wires) would be great for me,
    and I dare say, many other hobbyists. The direction of the top wires is
    not critical, but ideally they should be simple straight links, without
    junctions iow point-to-point only, and not using component leads as vias.
    I have got reasonable (but not great) results using direct transfer of
    laser print-out. Have to use wide tracks and large spacings - but at
    least I can then do it myself. My next step up (better PCB) is to print
    the negative on overhead transparency using my ink-jet (sometimes
    over-print to thicken the ink) - then have a board done photographically
    from my 'negative'
    The cost of having a real negative made from a print out is actually
    more than having the board done from the negative! In in many cases this
    is even more expensive than the cost of the parts that go on the pcb!
    I have made a perfectly good pcb for a binary alarm clock using a pic -
    has been working sweetly for over four years now.
    On Thu, 7 Aug 2008, Anton Schoultz wrote to us saying :
    I do home etch from a laser printer using transparency paper (not the
    plastic clear stuff but some slightly cloudy paper designed specially
    for photo etching). Just print to the paper then expose the board
    against that in my UV box. I can get track widths down to .016" and gaps
    to 0.012" without any difficulty.
    If I want to go finer than that (or double sided or anything) I'll
    generate Gerbers and order a board from my friendly not-so-local PCB
    house - the cost is really quite reasonable and you get proper PTH with
    solder mask and silk screen.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
