EAGLE User Chat (English) Changing width of copper text
  • Subscribers 180 subscribers
  • Views 642 views
Hi all,
I did put a piece of text in copper on the bottom layer,
but I can't change the width of the copper. DRC gives me
an error because the width is to small. Any idea's?
Jesse
  • Richard_H
    Richard_H over 17 years ago
    J. op den Brouw schrieb:
    Hi all,
    Jesse
    Check if it is written with vector font and change the
    text's width with CHANGE RATIO.
    Ratio is defined by text width to text height.
    Richard Hammerl
    Hi all,
    Jesse
    And what are good/valid numbers? I changed the ratio to 15%, but still
    getting DRC errors.
    Jesse
    Hi all,
    Jesse
    getting DRC errors.
    Jesse
    Hello Jesse,
    It depends on what you have set as the minimum width in the DRC check
    and the size of the text: Ratio is defined by text width to text height.
    I use 1.778mm (0.07")text and a 16% ratio with the (standard) 10mil
    minimum width.
    The important thing is to set the minimum width in the DRC so that your
    boardhouse will accept the gerbers; the standard should be fine. After
    that put your text in the desired height and just keep increasing the
    ratio until the DRC accepts it. If your text gets unreadable you should
    use a larger size. In your next board just use the same settings.
    HTH
    Richard Herman
