EAGLE User Chat (English) automatic routing of jumpers connected to different net classes
  • Subscribers 179 subscribers
  • Views 486 views
Hello, Eagle Users;
Any help is much appreciated --- Please take a look on attachments;
GOAL:
I need to create wires for the "same logical nets", but with different
withs (power ratings), and route them automatically;
For example, say I have +5V and GND nets that feed a high power load as
well as low power signal sense load --- see schematics;
SOLUTION:
I am trying to solve this by creating an smd jumper that looks like wire
with 2 pins, basically a zero resistance shunt resistor; this shunt
shows up in schematics as a separate component;
PROBLEM
When 2 smd pads of this shunt are indeed connected with a wire, as part
of device package, auto router does NOT rout shunt/jumper at all;
when you create a package without a wire, the auto route just fine;
Please let me know:
a) is there a better solution for the original goal
b) what to I do to resolve the problem with current solution?
Thank you,
John.
       Link for attachments mentioned in previous post:
       http://www.mediafire.com/carrotgarden
    user@domain.invalid wrote:
    Hello, Eagle Users;
    GOAL:
    SOLUTION:
    PROBLEM
    Please let me know:
    Thank you,
    John.
    <user@domain.invalid> wrote in message
    news:gavfha$ig0$1@cheetah.cadsoft.de...
    Hello, Eagle Users;
    GOAL:
    SOLUTION:
    PROBLEM
    Please let me know:
    Thank you,
    John.
    Hi, John
    Don't see that anyone else is answering so I'll give it a shot, but I'm a
    bit new to Eagle so excuse me if my answer isn't the best one. This is the
    way I'd go about it...
    Power traces are the ones I run first, and I use power supply symbols so I
    don't have wires all over the place in the schematic. The other advantage is
    that it is easy to connect and disconnect the symbols.
    I'd start by defining classes for all the wire sizes I intend to use in a
    project. Just type the word  class  in the command bar in either the
    schematic or the board editor, make sure each class meets boardhouse specs.
    Now, in schematic editor, connect all signals that you wish to all be of one
    size wire. For power, just place the appropriate symbol into the editor and
    (important) use the net command to join the symbol to the part pin. This
    creates an airwire in the board editor. Continue until you have all items of
    the same class connected and they all have airwires. Save your work. Go to
    the board editor and click Change and select Class. Click the class wanted,
    even if the check mark is already on the desired class setting. Now click
    one of the airwires, the whole net will highlight for a moment. Click Info
    and make sure all airwires you want for that class really now are of that
    class. Now, click the autorouter and leave on only the layer/s you wish to
    route this section of this nest onto. Then click the Select button, and then
    click the nest airwires, then click the traffic light icon (above the
    command bar), don't click the Stop icon accidently. The autorouter will now
    route as directed; you can manually tweak the routing, or ripup and draw
    temporary wires around areas you don't like where it routed to and do the
    select autoroute procedure again.
    Now, connect the same symbol previously used, in schematic editor, to the
    pins for the next smallest class to be routed to the same net that was
    previously routed already. More airwires appear. Set the class for these
    airwires, and let it route. Repeat until your smallest wires have been
    routed for the net that now has a common signal but differing trace widths.
    You're finished with that specific net, time to move on to another one.
    Sometimes a symbol is not practical. In that case you have to route a class
    before routing another class to the same net. But remember not to connect a
    signal to a pin unless you've finished with the previous class for that
    specific net, because you have to assign a class to an airwire and when you
    click a particular airwire any others belonging to that same net and not
    yet routed will get the new class you specify from then on & after!
    Ok, it's not fully automatic. Just semiautomatic. But it doesn't require
    jumpers, either. I hope this info helps.
    RGM, thank you very much, great answer. John.
    Hello, Eagle Users;
    GOAL:
    SOLUTION:
    PROBLEM
    Please let me know:
    Thank you,
    John.
    Hi, John
    a bit new to Eagle so excuse me if my answer isn't the best one. This is
    the way I'd go about it...
    I don't have wires all over the place in the schematic. The other
    advantage is that it is easy to connect and disconnect the symbols.
    a project. Just type the word  class  in the command bar in either the
    one size wire. For power, just place the appropriate symbol into the
    editor and (important) use the net command to join the symbol to the
    part pin. This creates an airwire in the board editor. Continue until
    you have all items of the same class connected and they all have
    airwires. Save your work. Go to the board editor and click Change and
    select Class. Click the class wanted, even if the check mark is already
    on the desired class setting. Now click one of the airwires, the whole
    net will highlight for a moment. Click Info and make sure all airwires
    you want for that class really now are of that class. Now, click the
    autorouter and leave on only the layer/s you wish to route this section
    of this nest onto. Then click the Select button, and then click the nest
    airwires, then click the traffic light icon (above the command bar),
    don't click the Stop icon accidently. The autorouter will now route as
    the select autoroute procedure again.
    the pins for the next smallest class to be routed to the same net that
    was previously routed already. More airwires appear. Set the class for
    these airwires, and let it route. Repeat until your smallest wires have
    been routed for the net that now has a common signal but differing trace
    widths. You're finished with that specific net, time to move on to
    another one.
    class before routing another class to the same net. But remember not to
    connect a signal to a pin unless you've finished with the previous class
    for that specific net, because you have to assign a class to an airwire
    and when you click a particular airwire any others belonging to that
    same net and not yet routed will get the new class you specify
