EAGLE User Chat (English) single PCB design into a large PCB with multiple single board designs
  • Subscribers 179 subscribers
  • Views 357 views
Former Member over 17 years ago
I know this has come up many times in the past but I was wondering if
anyone has come up with a solution. I have designed a 4 layer PCB, I now
want to take eight of the exact design of that PCB and put it onto a
larger board. I really do not want to reroute each of the 8 since they
would be the same. I know you can not group and copy because of circuit
duplication. Anyone know of a way around this?
  • Morosh
    Morosh over 17 years ago
    "Mike Hart" <mhart@patchbays.com> wrote in message
    news:gb0i4b$t8k$1@cheetah.cadsoft.de...
    want to take eight of the exact design of that PCB and put it onto a larger
    board. I really do not want to reroute each of the 8 since they would be
    the same. I know you can not group and copy because of circuit duplication.
    Hi:
    try "array_board-v5.zip" available in ulp download area.
    Regards
    Maurice
    Former Member over 17 years ago in reply to Morosh
    Hi Maurice,
    I did try the "array_board-v5.zip". I did everything in the instructions
    but kept getting a "parse error". Tried everything I could think of but
    could not make it work. I thought it might be the board I was working on
    so I tried a simple 2 layer board but got the same error. "NBR_MODX,
    NBR_MODY and give them the appropriate *  value" is this the distance
    you want the boards spaced? I also tried panelize.ulp but could not get
    this to work either.
    Hi:
    Regards
    Maurice
  • Morosh
    news:gb8jqg$5p5$1@cheetah.cadsoft.de...
    Hi Maurice,
    NBR_MODY and give them the appropriate *  value" is this the distance you
    want the boards spaced? I also tried panelize.ulp but could not get this
    to work either.
    Hi:
    Regards
    Maurice
    Sorry:
    there was a small mistake, a missed ";" at end of line, it was corrected and
    uploaded, now it's "array_board_v51.zip".
    Regards
    Maurice
    Hi Maurice,
    to work either.
    Hi:
    Regards
    Maurice
    Sorry:
    Regards
    Maurice
    Worked great, many thanks to Maurice.
