EAGLE User Chat (English) Can't delete layer
  • Subscribers 178 subscribers
  • Views 426 views
Can't delete layer
Hello all,
I had a board that was 6 layer. After some changes I have managed to make
the board route in 4-layers quite readily. Then I went to delete the layers
from the layer display. It let me delete layer 4, but not layer 5.
Obviously something is still using layer 5, but it is not displayed. Is
there some way to find anything on this layer? I have tried turning off all
layers except 5 and see what is displayed. Nothing is displayed in this
case. My board design rules makes no reference to layer 5 and the router
setup make no reference to layer 5 either.
Thanks for listening,
Eldon R. Hiebert
    Eldon Hiebert schrieb:
    I tried this solution yesterday and still cannot find the reason why I can't
    delete the layer.
    I should mention that this is V5.2.0 Professional. I need a solution for
    this; otherwise, I cannot get the board out for manufacture with known
    problems. Please help.
    Eldon R. Hiebert
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:gbbm0b$ptl$1@cheetah.cadsoft.de...
    Try: set used_layers all, enter & after that switch all layers on
    r
    Yeah, sems to be a little trouble with that. I try tests with a copy
    only but don´t have a 6 layer at hand right now. Usually one can delete
    a layer like "layer -x" where x = layer number, except if "layer is not
    empty". But give a try as Mr. Rafetseder suggested:"set used_layers 1".
    This should leave only a few layers and you can add the missing ones.
    No good solution but maybe a work around.....AND maybe you should check
    DRC /layers if your unwanted layer is still in the formula.
    Gruß
    Jörn
    delete the layer.
    Eldon R. Hiebert
    r
    Gruß
    Jörn
