EAGLE User Chat (English) Importing a package from a lib to another?
  • Subscribers 179 subscribers
  • Views 406 views
thanerd
thanerd over 17 years ago
I'm pretty new to Eagle, and i'm using it for a single board layout.
As i'm using a component that's not available in the library, i wanted to
design my own library item. Basically, it's a QProx QTouch item, the
QT110A-ISG. It is a SOIC-8 chip.
So when i "designed" it, i created an ugly package that, i though, would do
the trick. But it actually doesn't.
Minutes ago, by reading this forum, i saw there already was an SOIC-8
package in ref-packages.lbr.
So my question is, how do i link my schematic for the QT110A-ISG (in
quantum-research-group.lbr) to the package SOIC-8 in ref-packages.lbr?
Thanks in advance!
    to design my own library item. Basically, it's a QProx QTouch item, the
    do the trick. But it actually doesn't.
    Thanks in advance!
    With your new lib opened use the eagle control panel navigate to
    ref-packages.lbr and highlight the SOIC-8 popup menu  or main menu
    should offer copy to lib.
    Paul R.
  • thanerd
    Thanks alot, that works!
    But i actually was so bored that i finally opened the ref-packages lib and
    used the copy/paste method... Not the cleanest, but it did the trick too.
