EAGLE User Chat (English) Eliminate 90 degree bends
  • Subscribers 187 subscribers
  • Views 432 views
I'm trying to eliminate 90 degree bends (actually the corners) in traces
with the autorouter. I've played around with the settings for mnExtdStep
and cfExtdStep but either I have not come up with the correct
combination or I should be making the changes in another area as I still
get 90 degree corner bends. Anyone have any advice?
  • Richard_H
    Richard_H over 17 years ago
    Mike Hart schrieb:
    Anyone?
    IMHO cfExtdStep and mnExtdStep are not appropriate for this purpose.
    They are meant to avoid 45 degree bends in the layout.
    What you could try is to modify cfDiagStep and cfOrthStep:
    They are set to 3 (Diag) and 2 (Orth). This means that a diagonal
    step (45 degrees) costs 3 credits. The same step in orthogonal
    (for example one step left und one step up) would cost 4 credits.
    The Autorouter basically will prefer the 45 degree step, but there
    are lots of environmental effects that will cause hom to use
    90 degrees steps.
    Try to increase cfOrthStep carefully to make these steps more
    expensive. This might help.
    Richard Hammerl
