EAGLE User Chat (English) Routing fine pitch SMD
  • Subscribers 178 subscribers
  • Views 310 views
Hello all,
The router seems to have difficulty routing small pitch devices. My MAX3000A
is TQFP-100 @ 0.5mm pitch. With a grid of 5mil it leaves many of the pins
unrouted, eventhough there is lots of routing space on the inner layers.
I have alreayd optimized placement for the airwires so that I get as few
crossings as possible and the shortest nets (tradeoff here), but there must
be more I can do to this to ease the routing task.
Q: What are the specific clearances that I need to set in the router to help
route these parts? (ie. increasing pad to via keeps the router from placing
vias too close to the part and crowding neighboring pads).
Q: Does it make sense to manually route from the pads, out away from the
parts to provide more clearance for vias and wires?
Am I asking too much from the router? I wouldn't think so.... as there is
tons of free space. A small pic of what I have so far included.
TIA,
Eldon.
    Eldon Hiebert wrote:
    Hello all,
    TIA,
    Eldon.
    Your routing grid and the package pitch do not match, so the auto router
    won't work.
    You would need to change the grid to a metric value of 0.5 mm or a
    smaller but compatible value to allow the package pins to coincide with
    the grid.
    John G.
    "John Giddy" <jgiddy@bigpond.net.au> wrote in message
    news:gbu8m9$c5c$1@cheetah.cadsoft.de...
    Hello all,
    MAX3000A
    must
    help
    placing
    TIA,
    Eldon.
    won't work.
    You would need to change the grid to a metric value of 0.5 mm or a smaller
    but compatible value to allow the package pins to coincide with the grid.
    John G.
    That's not the problem actually. The pitch is 0.5mm and my routing grid is
    set to 5 mil which is about 3 times smaller than the fine pitch parts. The
    router still seems to choke the area around the fine pitch stuff in such a
    way that it is even impossible to manually route after the auto-router runs.
    Using select with the auto router helps, but still does not complete the
    entire part, and again, the crowding makes it hard to manually route
    afterwards.
    I guess I am just expecting too much from the autorouter, and need to stage
    my route in phases. I really wish I could select routing air wires by class.
    Eldon.
    Hello all,
    MAX3000A
    must
    help
    placing
    TIA,
    Eldon.
    won't work.
    John G.
    afterwards.
    Eldon.
    The grid may be "about" 3 times smaller than the pitch, but it is not
    exactly 3 times smaller.  The origins of the pins are not on the
    intersections of the routing grid.
    Mixing metric and imperial measurements is asking for trouble in my opinion.
    John G.
