EAGLE User Chat (English) Thicker net wires in schematic?
  • Views 1527 views
I do a lot of power electronics circuits which have a mixture of circuits
with low currents and circuits with high currents.
I would like to show the higher current circuits by making the net wires
thicker.
Is there a way to do this?
Tim
Offgrid Engineering
    Tim Economu schrieb:
    Whohoo!! Thanks that worked great for already placed nets...
    I strongly recommend to work through the tutorial before starting to
    work with EAGLE. Also make use of manual and online help...
    Tilmann
    Only problem is that I need to know allowable widths ...
    Any width is "allowed" - it's up to you to draw a readable schematic.
    BTW, please do not top-post.
    Read <http://www.netmeister.org/news/learn2quote2.html>
    and <http://www.cadsoft.de/newsguide.htm> (3)
    Tilmann
    maybe after I get more time on Eagle....
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:gc24j1$ral$2@cheetah.cadsoft.de...
    thicker.
    Tim
    Offgrid Engineering
    You could use
    SET NET_WIRE_WIDTH width;
    or in short
    SET NET width;
    to change the net width while drawing the schematic.
    Richard Hammerl
    "Lorenz" <lorenznl@yahoo.com> wrote in message
    news:7ho8e4lkbt7pvo4irb4k77oksgikmte33v@4ax.com...
    thicker.
    'change width'
  • Richard_H
    Richard_H over 17 years ago
    thicker.
    Tim
    Offgrid Engineering
    You could use
    or in short
    SET NET width;
    Richard Hammerl
    thicker.
    'change width'
