EAGLE User Chat (English) 6.2 -> 6.5 BOM.ulp changes
  • Views 844 views
jameslittlefield
jameslittlefield over 12 years ago
Just trying to finish up my first design done in 6.5.  When I run bom.ulp I
no longer see the option to load a database (TSV) file.   Is there a way to
use a previously created TSV file to initialize the attributes of all the
parts and then run bom_with_attributes.ulp to get the previously defines
information.
I'm really not wanting to have to manually re-enter all the information
from all my *.tsv files for all each legacy design.
Jim
    autodeskguest over 12 years ago in reply to jameslittlefield
    On 22/12/2013 3:49 a.m., James Littlefield wrote:
    Hi Warren,
    Thanks for the RTFM!
    You're welcome, I have a whole heap of them to give out at Christmas.
       I had already perused those resources.   I think I
    was not sufficiently clear in my earlier message.   My complaints with the
    new attribute based bom handling are..
    1.  If I have 15 2.2K resistors,  go into the schematic and add attributes
    for price, Dk part number,  etc   the attributes are added to only one of
    the parts.
    Correct, adding an attribute in the schematic gives the selected named
    part the attribute, not the device type.
      With the old system I could have the bom sorted by component
    value,  create some custom columns in the tsv file, add the information
    once, and have it apply to all the components of the same value, footprint.
    Yes, the information is being added to the output of the ULP. That is
    akin to adding it at a later date in a spreadsheet. The eagle design is
    not being affected.
      The only way I can see to work around this in the newer method is to have
    to create a custom library for every project,  copy all the components used
    in that project into the custom library, and then add the attributes in the
    custom lib.
    Even if you have a single well maintained personal library folder from
    which all your projects are drawn, it would be hell to maintain all the
    part numbers for all resistor values in all package types. There have
    been earlier discussions that attributes are not a desirable method of
    referencing supplier part numbers. Going forward, a BOM/database
    solution is needed.
    2.  I was not meaning to imply that if I change a resistor package that the
    new part would somehow magically have the correct attributes (other than
    footprint).... but I could expect that it NOT have the attributes of the
    part that was previously there which is what happens in 6.2.
    The attributes that are there pertain to the named part on the
    schematic, not the part in a library context(as said earlier). Any
    attributes that were established in the library do change with the
    arrival of a different part.
         In the old
    bom handling method,   if I replace a 10K, 0805 with a 10K 0402, load the
    tsv/database file  I will see nothing for the 0402 (unless it was already
    in the tsv file).   This makes sense to me and when I find components in
    the bom listing that have no Dk part number/cost/or other custom
    information  I know to add it.
    I like this method. It's simple.
    Cheers,
    Jim
    First thoughts of modifying the ulp to import a TSV file and apply the
    values as attributes runs into the problem you mentioned. If you change
    the part, the attribute remains the same unless you run the BOM again
    and import the TSV again. But if the TSV does not address the new part
    name then it may retain the old erroneous part information unless all
    fields for a given attribute are cleared initially.
    So we are back to the old ULP, which works in v6.
    Have you seen http://www.cadsoftusa.com/downloads/file/bom-ex156.zip
    This effort by Bob Starr maybe of interest to you as it builds on your
    preferred approach, uses attributes and extends to ordering automation.
    All the best
    Warren
  • jameslittlefield
    jameslittlefield over 12 years ago in reply to autodeskguest
    Hi Warren,
    Thanks for the RTFM!  I had already perused those resources.   I think I
    the parts.    With the old system I could have the bom sorted by component
    custom lib.
    part that was previously there which is what happens in 6.2.    In the old
    Cheers,
    Jim
    On 21/12/2013 12:42 a.m., James Littlefield wrote:
    Bob...thanks for your suggestion.    I also used the old bom.ulp and it
    worked fine.   Its a good stopgap measure!
    Warren ..  My thought was that the information from the tsv file would be
    added to attributes of the parts on the schematic.   Then you could run the
    bom with attributes ULP and come up with a reasonable BOM preserving the
    labor invested in the original *.tsv files.
    Perhaps I don't understand how attributes are supposed to work but my
    initial impression is that they don't work that well.   As an example,  if
    you have created attributes for a schematic component (say digikey part
    number),  and then replace the part with a different package or change the
    value,  the custom attribute (dk part number) remains at the old value.
    At least with the older method (*.tsv/bom.ulp).   Is there a good on-line
    tutorial for how the attributes are supposed to be used,  how they interact
    with the bom generation process, etc?
    Thanks for your ideas,
    Jim
    Hi Jim
    Reading the HELP > attribute  is a good start.
    Then supplement that by reading the explanations in the manual found in
    the docs folder of  your installation files.
    Then practice what you read.
    In essence,
    1. Attributes created in the library reveal themselves in the  lib, sch
    and brd.
    2. Attributes created in the sch reveal themselves in the sch and brd
    3. Attributes created in the brd only pertain to the board
    4. Then there the global attributes for the board
    5. and separately, the global attributes for the schematic
    To have part numbers that automatically change when you change the
    package or technology, you will need to set up the attributes in the
    library by device variant.
    HTH
    Warren
  • jameslittlefield
    Jim
    information.
    Jim
    Hi Jim
    I can't see anything 'off the shelf' as that would be difficult to build
    for all users and their variations if it were library focused.
    Initially, where would you add the attribute information. In your
    libraries or as attributes attached to the parts within your schematic?
    If they are personal libraries and you have been controlling them and
    their names since v4 then you could target them. Otherwise I would merge
    the TSV information into your schematic for each design until you get
    the library parts matched with your supplier data correctly. In the v4
    bom.ulp the match for part to manufacturer info was partname:value so
    those combinations in your current design need to match for the TSV data
    to match and enter the new attribute. If that is the approach you want
    to take it would not take to much effort to knock up a ULP to do it.
    This approach is similar to that used previously. Previously the TSV
    data was merged with the result of the BOM.ulp output. The new way would
    be to merge the TSV into the schematic, creating new attributes/values
    and then run the current v6  BOM.ulp that reads attributes.
    Warren
    I
    to use a previously created TSV file to initialize the attributes of all
    the parts and then run bom_with_attributes.ulp to get the previously
    defines information.
    Jim
    I keep version 5 around for old projects, and on those occasions where I
    migrate one to version 6 but don't want to mess with attributes I simply run
    the old 'bom.ulp' in the version 5 ULP directory to pick up the old .tsv
    files. It still seems to run fine on version 6 projects.
    If there's a better way, I'd like to know also.
    Bob
