EAGLE User Chat (English) Where are the idc headers?
  • Replies 10 replies
  • Subscribers 178 subscribers
  • Views 3782 views
Hello!
Does anyone know where to get IDC headers library for eagle?
Regards
Artem
    Artem Kuchin wrote:
    Hello!
    Regards
    Artem
    Pinhead.lbr has the unshrouded headers.
    -Dave Pollum
    "David Pollum" <vze24h5m@verizon.net> ???????/???????? ? ???????? ?????????:
    news:48FA0E75.4030602@verizon.net...
    Artem Kuchin wrote:
    Hello!
    Regards
    Artem
    -Dave Pollum
    Yes, i've seen them. But pinhead.lbr is not IDC, it does not even have pin 1
    marked. Besides that, this way
    board generation will not work.
    Artem
    Artem Kuchin wrote:
    Hello!
    Regards
    Artem
    -Dave Pollum
    Artem
    Connectors are generally in con- libraries. Try com-3m or con-panduit.
    Gruß
    Jörn
    Artem Kuchin wrote:
    Hello!
    Regards
    Artem
    -Dave Pollum
    Artem
    So I guess I don't understand what you mean by an IDC header.  Do you
    mean a connector that has PCB pins that crimps onto ribbon cable (i.e.
    Digikey # MDM10H-ND)?  If so, modify an existing part, or make a new one.
    BTW: I've copied and modified the headers in pinhead.lbr, so that I have
    a square pad for pin #1, and round pads for the other pins.
    -Dave Pollum
    news:gdi5ov$abh$1@cheetah.cadsoft.de...
    ?????????: news:48FA0E75.4030602@verizon.net...
    Artem Kuchin wrote:
    Hello!
    Regards
    Artem
    -Dave Pollum
    pin 1 marked. Besides that, this way
    Artem
    So I guess I don't understand what you mean by an IDC header.  Do you mean
    a connector that has PCB pins that crimps onto ribbon cable (i.e. Digikey
    1. MDM10H-ND)?  If so, modify an existing part, or make a new one.
    BTW: I've copied and modified the headers in pinhead.lbr, so that I have a
    I mean like this
    http://www.futurlec.com/Connectors/IDCMH10.shtml
    (as welll as angled an? with a latch)
    i wonder, how come such widly used parts are not in the default libraries.
    Former Member over 17 years ago
    try con-3m or con-hdrs-40
    r
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> ÓÏÏÂÝÉÌ/ÓÏÏÂÝÉÌÁ × ÎÏ×ÏÓÔÑÈ
    ÓÌÅÄÕÀÝÅÅ: news:gdijju$8nr$1@cheetah.cadsoft.de...
    r
    Com-3m does have something close to ids, but pin 1 is not square.
    com-hdrs-40.lbr does not exist
    Artem
    r
    Artem
    If you can not read, that´s your poblem. Rafetseder said coN-hdrs and it
    DOES exist.
    Gruß
    Jörn
    "Joern Paschedag" <jpaschedag@t-online.de> ÓÏÏÂÝÉÌ/ÓÏÏÂÝÉÌÁ × ÎÏ×ÏÓÔÑÈ
    ÓÌÅÄÕÀÝÅÅ: news:gdl91v$83e$1@cheetah.cadsoft.de...
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> OIIAYEI/OIIAYEIA ?
    II?IOONE OIAAOAYAA: news:gdijju$8nr$1@cheetah.cadsoft.de...
    r
    Artem
    If you can not read, that?s your poblem. Rafetseder said coN-hdrs and it
    DOES exist.
    I cannot TYPE and that's my problem fot sure.
    I meant coN, of course.
    And it does not exist at all in the lbr dir of my newly intslalled EAGLE 5.2
    niether it exists in EAGLE 5.0
    Something is wrong here.
    r
    Artem
    DOES exist.
    There are other(user)libs available at the download area of cadsoft and
    so is this one image
    Gruß
    Jörn
