EAGLE User Chat (English) Global search for a part in all libraries
  • Subscribers 187 subscribers
  • Views 449 views
I may be misssing something. It takes me sometimes half and hour just to
find a needed part
in all those libraries (default+downloaded).
Is there any way to search them all at once?
Also, is there any way to add several libraries at once and not one by one
by use command
from menu?
Artem
    Artem Kuchin schrieb:
    And as i can see, there is not way to open the USE dialog  and add several
    libraries at once.
    HELP USE
    USE *   (to put /all/ libreries "in use")
    To re-select your "project" libs you could write a small script.
    However, I prefer to always select all of my image libraries. I have put
    the libs that come with EAGLE aside in a separate folder (for reference
    purposes - I only use my own ones).
    Tilmann
    P.S. Please get a working newsclient or install OE-Quotefix to correct
    line wrapping. (Content type and charset declaration are also missing.)
    "Joern Paschedag" <jpaschedag@t-online.de> ???????/???????? ? ????????
    ?????????: news:gdjmei$1qk$2@cheetah.cadsoft.de...
    find a needed part
    one by use command
    from menu?
    Artem
    Help add, see the search function.
    Search work only for the USED libraries. I can do "use all" in the control
    panel, but that
    screws my personal favorite list of libraries for the project. So, is ther
    way to find a library with a
    needed part without touching current list of libraries and without adding
    and removing libraries
    one by one.
    libraries at once.
    Artem
    find a needed part
    by use command
    from menu?
    Artem
    Gruß
    Jörn
