EAGLE User Chat (English) Newbie: Off-grid SMT components
  • Subscribers 179 subscribers
  • Views 549 views
I have recently started using Eagle.  I am trying to place 0805
components and am having a problem because the pads in the standard
library are off of the grid (50 mil).  If I place the component
horizontally and then try to route a trace from the side of the
component, the trace does not exit the center of the pad but instead the
trace is aligned to the grid and is offset from the center of the pad.
The only way I can get it to work is to use a very fine grid.
However, if the component is rotated vertically a trace exits from the
center of the pad even if the pad is off grid.
Thank you,
Kerry
    Kerry S. Martin schrieb:
    Thank you,
    Kerry
    Yes, the TRH are in inch and the SMD are in Millimeters, so the grid
    "never fits". Anyway, choose the grid you want to work with. Eagle has a
    "grab" function that works in such a way that if you start routing close
    to a pad, the center of the pad will be grabbed even if that is off grid.
    Your rounting then continues on the choosen grid. To connect to a
    different part, you stop the routing a little before reaching that part
    and start new from the pad of the other part, so the "grabbing" can take
    place again.
    In other words, if you have mixed mm/mil layouts allways route away from
    the parts.
    Gruß
    Jörn
    How do you actually do this? Do you work with a script or can it be done by
    invoking the autorouter and the gui?
    "Joern Paschedag" <jpaschedag@t-online.de> wrote in message
    news:ge1siv$p7b$1@cheetah.cadsoft.de...
    Thank you,
    Kerry
    place again.
    the parts.
    Gruß
    Jörn
    Jörn,
    Thank you for your helpful answer.  I have found that if I use a wire
    bend of 1 to start on a component, and 3 to end on a component, that the
    "grab" function that you described gives me the result that I want.  If
    I have two components side-by-side and I want a trace directly from the
    center of one pad to the center of the other, I use a wire bend of 2 and
    it produces the desired result.
    Thank you so very much,
    Kerry
    the trace is aligned to the grid and is offset from the center of the
    pad. The only way I can get it to work is to use a very fine grid.
    Thank you,
    Kerry
    place again.
    the parts.
