    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
EAGLE User Chat (English) Making copies of symbols in libraries
Autodesk EAGLE requires membership for participation - click to join
  • Subscribers 145 subscribers
  • Views 133 views
autodeskguest over 15 years ago
Why can't symbols be copied like packages and devices?  If I want to
use a symbol from another library, the only way I have found to do it
is to copy a device containing that symbol, and then remove the device
and the packages that came with that device.  Isn't there a more
straightforward way to do it?
Robert Scott
Real-Time Specialties
Ypsilanti, Michigan
    Hi - First Post - step by step:
    1. Open library at desired symbol;
    2. Set Display so layers 91 to 98 All selected;
    3. Group symbol with Group button to include its >Name, >Value etc;
    4. Type command CUT (0 0) ;
    5. Select File New  to get new untitled.lbr ();
    6. Press Symbol button to get Edit Symbol box ;
    7. Enter name of New: Symbol and press OK ;  I chose TEST
    8. Select Yes in Response to "Create new symbol 'TEST' ";
    9. Press Paste button on sidebar;
    10.  Drag and drop symbol over origin.
    I made a simple script file containing CUT (0 0) and added it to my setup.
    Hope that helps!
    Ed Phaneuf
    On Sat, 25 Oct 2008 19:26:35 -0400, Ed Phaneuf <ephaneuf@rogers.com>
    4. Type command CUT (0 0) <enter>;
    Hope that helps!
    It certainly does.  It works perfectly.  Like so many things, it is
    obvious once you know how.
    Robert Scott
    Ypsilanti, Michigan
    On Sat, 25 Oct 2008 17:56:42 -0400, Robert Scott wrote
    (in article <4903956e.12801609@news.cadsoft.de>):
    +1
    I copy symbols as much as I copy packages or devices.  I'm glad to see
    someone else ask the same question.
    Cheers,
    James.
     James Morrison  ~~~  Stratford Digital
     email:  sales@eagletoolkit.com
     fax:    888.701.8097
     web:    http://www.eagletoolkit.com
     Online EAGLE Dealer for US and Canada
     EAGLE Design Experts
     EAGLE Enterprise Toolkit
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
