    • Avnet Boards Community
EAGLE User Chat (English) Board outline
  • Subscribers 171 subscribers
  • Views 280 views
Board outline
Hello!
I'm a n00b at Eagle, and I'm still working on one of my first boards.
Anyway, I'm trying to render a board to PovRay, but it needs a board
outline.  I didn't create it in the schematic, so it doesn't already
have one.  How do I add it?
    Etharooni wrote:
    Hello!
    You create it in the board editor, not the schematic.
    Just draw it on layer 20 (dimension) with the "wire" tool.
    John G.
    Thanks!!!  I knew it would be something simple like that.
    John Giddy wrote:
    Etharooni wrote:
    Hello!
    John G.
    On Mon, 27 Oct 2008 11:34:28 +1100, John Giddy <jgiddy@bigpond.net.au>
    wrote:
    Etharooni wrote:
    Hello!
    I see that layer 20 info gets written to the top side silkscreen
    gerbers in the CAM processor.  However, what do you do if you are
    making a "bare-bones PCB" board using Advanced Circuits in Colorado?
    Such a board does not have a silkscreen layer.  It takes only a top
    and bottom solder layer and the drill file, of course.  In that case I
    often draw an outline using top and bottom copper wires.  But even
    then Advanced Circuits does not always trim the board where I want it,
    even when I tell them explicitly in the instructions.  Maybe I should
    just send them the Eagle file instead of the gerbers and let them sort
    it out.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
