EAGLE User Chat (English) Reusing packages into new libraries
  • Subscribers 177 subscribers
  • Views 377 views
Is there a way to copy existing packages from any library into another?
  I'd like to create a new library and add existing packages to it and
then go through the usual part creation process.  In the past, I've
added a new device into an existing library to utilize it's available
package choices.  I suppose I could also copy & rename an existing
library with Total Commander and then edit the contents as needed, but
it that there should be a more obvious method than that..
Note: Running Standard 4.16 if that makes any difference.
Thanks!
    Found it in the manual...
    Thanks!
    Thanks!
    If you are adding parts to one of the Eagle-supplied libraries, then
    you will lose your changes whenever you upgrade to a newer version of
    Eagle, which will re-install all the factory-fresh Eagle libraries.
    Make one or more custom libraries that are all your own.  If you have
    your custom library open, then you can drag a package from any other
    library by finding it in the Eagle control panel and dragging away.
    Same thing for devices.  Unfortunately you can't copy symbols this
    way.  However you can copy symbols by following the method described
    by Ed Phaneuf on 10/25/2008 in this forum.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
    Was not aware of that--excellent tip!
    Thanks!
    Robert Scott
    Ypsilanti, Michigan
