EAGLE User Chat (English) GND polygon
  • Subscribers 177 subscribers
  • Views 284 views
GND polygon
I have a bit of a n00b question.  How do you create that GND polygon or
whatever you call it like the big ol' blue shape in this:
http://farm4.static.flickr.com/3239/2709834302_78b27bfe5f_o.jpg
Thanks.
    Thanks.
    Draw your polygon around the area that you want to have a ground plane (I
    generally outline the whole board :-). Click on the "rename" icon, then
    click the edge of the polygon, and name it "GND" (or "VDD", or whatever).
    Voila! Note that if you use a ground plane to make all your ground
    connections, you need to watch for any airwires where the ground plane
    can't connect to somewhere; you may need to manually route a ground line
    to make any such interconnects.
    BTW, don't forget to change (the wrench icon) the Isolation value (then
    click your ground plane) as needed; click on the ratsnest icon to refresh
    the ground plane display.
    HTH
    DMerriman
    Thanks.
    HTH
    DMerriman
    Thanks!
