EAGLE User Chat (English) Copying from one eagle board to another
  • Replies 8 replies
  • Subscribers 180 subscribers
  • Views 943 views
How do you do that?  I want to get a component from one board onto
another one.
    Former Member over 17 years ago
    All layers on, then group, cut, in the new brd paste. See also the online
    help
    r
    help
    r
    Thanks, but on the second board it says "paste buffer is empty"
    You forgot to click the cut-button (scissors) ,
    Eagle is different to win$s.
    r
    r
    It works all within one board, but when I try to copy to another, it
    doesn't work.
    You forgot to click the cut-button (scissors) [Ctrl-C will not
    work!], Eagle is different to win$s.
    r
    doesn't work.
    I presume you have two eagle programs open and try to copy from one to
    the other. This does not work because each eagle has its own paste
    buffer and not a common shared one.
    So, as Rafetseder wrote already, (only one eagle program running)
    group, cut, then go to the new or other existing board and paste.
    Help (or F1) CUT
    Gruß
    Jörn
    autodeskguest over 17 years ago in reply to autodeskguest
    Is there absolutely no way to copy from one board to another?  I ran
    into the problem again.
    r
    doesn't work.
    Help (or F1) CUT
  • Richard_H
    Richard_H over 17 years ago
    r
    doesn't work.
    Help (or F1) CUT
    As Joern already tried to explain, it works (as in various posts here
    described):
    DISPLAY ALL layers
    Use GROUP to select all objects
    Click the CUT icon AND click into the drawing to set a reference point
    Edit the other board with File/Open
    Use PASTE to place the group
    HTH
    Richard Hammerl
    Oh. I see.  Sorry.
    r
    doesn't work.
    Help (or F1) CUT
    described):
    DISPLAY ALL layers
    HTH
