EAGLE User Chat (English) Board Design Question
  • Subscribers 187 subscribers
  • Views 316 views
Is it possible to create a board where some of the components are below
board coordinate 0,0?
For example 4 LEDs one centered at each of the coordinates 1,0, 0,1, -1,0
and 0,-1.
I am using ver. 5.3 Standard Edition.
  • Richard_H
    Richard_H over 17 years ago
    and 0,-1.
    The Standard edition has a limitation in the board size. You are allowed
    to place components with in the coordinates (0 0) (160 100) .
    So the limitation of the Standard edition does not allow you to
    place a component for example at (0 -1).
    But you could set a relative origin with the MARK command and work
    with relative coordinates.
    Richard Hammerl
