EAGLE User Chat (English) Library Part
  • Subscribers 184 subscribers
  • Views 307 views
Library Part
Is there a step by step instructions on how to add a part to the library (I
have the data sheet) or make changes to an existing part? I read the maunual
but could not follow through with building an item to add to the library.
Any help would be greatly appreciated.  Thanks.
    On Mon, 17 Nov 2008 22:51:13 -0800, "sergenet" <sergenet@yahoo.com>
    At the beginning it is easier to make a copy of the package and symbol
    into a custom library of your own and then play with it there.  Making
    a library device from scratch is quite involved and you should expect
    to spend a good deal of time learning.  Basically it is divided into
    three steps:
    1.  Creating the symbol or symbols used in the schematic layout.
    2.  Creating (or copying) the package used in the board layout.
    3.  Making a "device" by defining the connections beteen the pins of
    the symbols and the pins of the package.
    If you make a drag a copy of device from an existing library into an
    experimental library of yours, then you can play around with all these
    actions and learn a lot that will help you understand the manual.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
    Former Member over 17 years ago
    Here's an excellent set of video tutorials "download for best quality"
    http://tangentsoft.net/elec/movies/
