EAGLE User Chat (English) Viewmate and drill (drd) files
  • Subscribers 178 subscribers
  • Views 556 views
CasaDelGato
CasaDelGato over 17 years ago
I'm attempting to use ViewMate to view my gerber files before
submitting them to PCBExpress.
The problem is that the .drd file seems to have the drill pattern MUCH
larger than the top/bottom layers, nor does it even look like it would
be correct if it was scaled down.
I'm pretty sure the problem is the way I'm using ViewMate to view
them.  Anyone used this tool with EagleCAD/PCBExpress gerber files?
Suggestions?
  • Richard_H
    Richard_H over 17 years ago
    Suggestions?
    I suppose you have to define the data format of the EXCELLON
    data you want to import into ViewMate.
    EAGLE exports 2.4 format in inch.
    Richard Hammerl
