EAGLE User Chat (English) Only input pin
  • Subscribers 185 subscribers
  • Views 740 views
Only input pin
Former Member over 17 years ago
Hello Eagles,
I am using the ERC and get the following error on a PAD --- WIRE --- PIN of
a MAX232 pin R1IN and R2IN : Eagle says that we should Only input pins on
net N$27.
The pin R1IN of the MAX232 is an input RS232 READ signal.
Have anyone a clue to help me!
Thanks in advance,
Pierre.
    Pierre Ghislain wrote:
    Hello Eagles,
    PIN of a MAX232 pin R1IN and R2IN : Eagle says that we should Only
    input pins on net N$27.
    I think the ERC message you're referring to indicates that there are ONLY
    input pins on the net.  What is this R1IN input pin connected to?  It should
    be connected to an OUTPUT of some other device to drive it.
    Bert Menkveld
    Hello Eagles,
    of a MAX232 pin R1IN and R2IN : Eagle says that we should Only input
    pins on net N$27.
    Thanks in advance,
    Pierre.
    That is only a warning.
    Normally you should not have inputs not connected to outputs.
    You did not tell Eagle you will use the PAD as "output" to the net.
    Easiest is just to approve it in the dialog (only Version 5)
    Or change library/part so the pad is output.  (or MAX232 PAS or
    something else, but that is not elegant)
    On Wed, 19 Nov 2008 07:38:42 -0500, "Bert Menkveld" <bert@betech.biz>
    Hello Eagles,
    R1IN and R2IN should be connected either to a pin of a  RS-232RS-232
    connector or to GND.
    -Dave Pollum
