EAGLE User Chat (English) Updating from Earlier Version
  • Views 631 views
I get the message, "Updating from Earlier Version" the first time I
use a Library after starting Eagle 5.3.0.  I assume this message has
to do with the Library, but I cannot decide why I get this message.  I
have downloaded the latest Libraries from the Cadsoft website.  Does
anyone know why I am getting this message and how to avoid it?
    On Wed, 10 Dec 2008 15:11:08 +0100, Richard Hammerl <ric@cadsoft.de>
    wrote:
    Paul schrieb:
    On Tue, 09 Dec 2008 08:53:25 +0100, Richard Hammerl <ric@cadsoft.de>
    Please check the setting of your library path in the Options/Directories
    menu of the EAGLE Control Panel. Does it point to the current libraries?
    If yes, maybe there are library files that are made and saved in an
    previous data format, for example of version 4.1.
    When reading such a library file EAGLE has to convert it first into
    versioin 5 data format. If you would open the older libraries and
    save them with EAGLE 5.3 the message would no longer be shown.
    The library path is correct.  I am sure you are correct about the
    older library.  I did open and modify one or two libraries in an
    earlier version.  The problem is, I don't know which ones.  Is there a
    way to identify which of the libraries might have been saved in an
    older format?
    Sturpe
    You could write a script file with one single line
    WRITE;
    Save it and then start run-loop-all-lbr-script.ulp.
    This ULP will read your script and loop through all you libraries
    in the current directory. So each lbr file will be saved and all
    libraries are stored in version 5 format.
    Thanks.  That did the trick.
    Sturpe
  • Richard_H
    Richard_H over 17 years ago
    older format?
    Sturpe
    WRITE;
    Richard Hammerl
    older format?
    Sturpe
  • Richard_H
    Richard Hammerl
