EAGLE User Chat (English) Custom SMD pads
  • Views 909 views
Custom SMD pads
How can I create a custom SMD pad in Eagle like the one in the image I
attached?
    Jay Beritz wrote:
    Bert Menkveld wrote:
    Jay Beritz wrote:
    image I attached?
    Doesn't someone know how to do this? Please help
    I'm afraid you're not getting a response because there's no simple
    way to do this.  Eagle does not provide any facility for arbitrary
    shapes of SMD pads. You could draw a polygon, but Eagle does not
    really support the use of polygons in library parts, so this will
    involve a great deal of trouble. If you want an SMD with one end flat and
    the other rounded, you
    could lay two short SMD pads on top of each other, one rectangular
    and one rounded. This will give you endless DRC errors, but could
    give you the SMD pad shape you want.
    Do you really need this appearance of SMD pad?  What's wrong with
    rounding both ends, or just keeping both ends square?
    Bert Menkveld
    I assumed the IC's pads and the traces on the board must match.
    If the trace on the board is touching an area on the IC that is not a
    pad won't this heat up the chip or cause other problems?
    If you look at the SMD IC package, you'll see that is has metal leads that
    are bent down to provide a small length of lead that sits on the pad on the
    board.  The rest of the IC package is plastic (non-conductive), and normally
    doesn't even touch the board.  You can therefore run traces from the pad
    underneath the package without any problems.  The pads themselves can have
    square or rounded corners, as different designers and different assembly
    procedures may prefer, but for DIY assembly, I don't think it matters.
    Take a look at some of the standard SMD footprints in the Eagle libraries to
    see how foorprints are typically done.
    Bert Menkveld
    Jay Beritz wrote:
    I attached?
    I'm afraid you're not getting a response because there's no simple way to do
    this.  Eagle does not provide any facility for arbitrary shapes of SMD pads.
    You could draw a polygon, but Eagle does not really support the use of
    polygons in library parts, so this will involve a great deal of trouble.
    If you want an SMD with one end flat and the other rounded, you could lay
    two short SMD pads on top of each other, one rectangular and one rounded.
    This will give you endless DRC errors, but could give you the SMD pad shape
    you want.
    Do you really need this appearance of SMD pad?  What's wrong with rounding
    Bert Menkveld
    Jay Beritz wrote:
    I attached?
    you want.
    Bert Menkveld
    attached?
