EAGLE User Chat (English) R1206 or M1206
  • Subscribers 177 subscribers
  • Views 1017 views
R1206 or M1206
Greetings,
I'm unsure of which land pattern to use for a 1206 resistor. In the Eagle
rcl libraries, R1206 and M1206 are listed. The M1206 land pattern pads are a
tad bigger than the R1206 land pattern pads.
Which should I use?
    Biff wrote:
    Greetings,
    Which should I use?
    There is no simple answer to this.  The pad pattern is process related
    and that is why there are so many duplicates in the parts lists.  What
    works well for hand soldering may cause tomb stoning in a reflow oven.
    You must decide for yourself once you have an understanding of how the
    part is to be soldered in production.
    HTH
    BrianT
    Thanks for the tip BrianT. I appreciate your input!
