EAGLE User Chat (English) SOIC-28   330mil
  • Subscribers 178 subscribers
  • Views 414 views
SOIC-28   330mil
I have a memory chip that is 330mil wide, rather than 300mil.
When I mounted on prototype PCB, it was a little tricky to ensure
connectivity.
I need to make a couple more hobby boards,
Is there a 330mil package outline for SOIC-28 available for download
anywhere.
    No one have anything on this to help?
    "6502Dude" <6502Dude@bjlyons.com> wrote in message
    news:gjc0g2$js3$1@cheetah.cadsoft.de...
    connectivity.
    anywhere.
    I think your lack of replies is a subtle call to RTFM.  There are
    tutorials on laying out your own parts at
    http://tangentsoft.net/elec/movies/ and numerous other sites.
    It is highly recommended you lay out your own as you can then ensure the
    pads are the sizes to suit your assembly method. Hand soldering is
    easier with a larger pad than you would use for hot air or IR reflow
    assembly for example.
    HTH
    Brian
    connectivity.
    anywhere.
    Thanks!
    I am newbie at Eaglecad.
    While I have done 4 pcbs now (and they work), it was a lot of work and a bit
    of luck so far.
    These tutorials are great!
    "BrianT" <bdtaylor@iprimus.com.au> wrote in message
    news:gju2bn$9t5$1@cheetah.cadsoft.de...
    I think your lack of replies is a subtle call to RTFM.  There are tutorials
    on laying out your own parts at http://tangentsoft.net/elec/movies/ and
    pads are the sizes to suit your assembly method. Hand soldering is easier
    with a larger pad than you would use for hot air or IR reflow assembly for
    example.
    HTH
    Brian
    connectivity.
    anywhere.
