EAGLE User Chat (English) Keeping revision history?
  • Subscribers 187 subscribers
  • Views 616 views
I'm looking for recommendations for keeping the revision history as part of
a design file (ie what has changed in this revision/release).
Was considering adding a new sheet to the schematic or making a history
layer for text. Are there any ULPs or scripts that are geared toward
maintaining the revision history? Is there any good way to link to a word
document file which would be more user friendly for keeping a history file?
Thanks in Advance,
Bob 'Oppie' Oppenheimer
    autodeskguest over 16 years ago in reply to autodeskguest
    Hello Oppie,
    I use SVN, it's great.  You can add a time stamp to a schematic by using
    text, in Names layer type  >Last_Date_Time.  Click save and then redraw.
    Mike
    "EAGLE user" <e4opening@yahoo.com> wrote in message
    news:gkkf1k$c2p$1@cheetah.cadsoft.de...
    James Morrison wrote:
    part
    of a design file (ie what has changed in this revision/release).
    word document file which would be more user friendly for keeping a
    history file?
    Thanks in Advance,
    I use tortoiseSVN:  www.subversion.tigris.org.  You can keep track of
    all changes to your design file.  If necessary you can rollback to
    previous versions if something goes wrong.  There is a little bit of a
    learning curve but it's definitely worthwhile. Any other documents BOM,
    test specs., etc. can also be place under revision control too.
    I fully agree that SVN is the way to go.  TortoiseSVN is a good Windows
    client.  There are command line tools for linux that probably come with
    most
    distributions.  I've recently started using RapidSVN that has clients for
    Windows, Mac, and Linux so it's the same GUI in all three platforms.
    Don't forget to backup the repository.
    Cheers,
    James.
    email:  sales2009@eaglecentral.ca
    fax:    888.701.8097
    web:    http://www.eaglecentral.ca
    Online EAGLE Dealer for US and Canada
    EAGLE Design Experts
    EAGLE Enterprise Toolkit
    Didn't now about RapidSVN.  I'll have to take a look at it. Thanks for the
    info.
    Cheers,
    Eagle User
    Thanks EU
    Was hoping to avoid another third party tool and keep the revision history
    as part of the document. We have a small very limited field on the schematic
    which gives the revision history. I wanted to make it include more
    information about what changed since the last release.
    I could also just reference an ECO in that limited field and then go to town
    with as much information as needed in the ECO. Engineering change
    documentation and management are part of our ISO9000 package that runs under
    Lotus Notes. Guess I should look more deeply into this first.
    Will download some of the SVN tools recommended and take a look.
    Oppie
    news:gkipsg$if0$1@cheetah.cadsoft.de...
    file?
    Thanks in Advance,
    I use tortoiseSVN:  www.subversion.tigris.org.  You can keep track of all
    changes to your design file.  If necessary you can rollback to previous
    versions if something goes wrong.  There is a little bit of a learning
    curve but it's definitely worthwhile. Any other documents BOM, test
    Cheers,
    Eagle User
    history file?
    Thanks in Advance,
    client.  There are command line tools for linux that probably come with most
    Cheers,
    James.
    fax:    888.701.8097
    the info.
    Cheers,
    Eagle User
    history file?
    Thanks in Advance,
    Cheers,
    James.
     fax:    888.701.8097
    history file?
    Thanks in Advance,
    Cheers,
    Eagle User
