EAGLE User Chat (English) inner-layer keepout
  • Subscribers 177 subscribers
  • Views 483 views
inner-layer keepout
Hello everyone,
Lets say I have defined Layer 2 as a filled polygon named 'GND', but there
are a couple of area I want to be void of the fill.  How would I go about
this?   I noticed there is a tKeepout and a bKeepout but nothing for
inner-layers.  I used the 'Wire' command and made a 'box' around the parts
in question, and this worked.  It didn't poly-fill within the box, but I'm
also left with the isolated 'wire' box.  I'd like to get rid of the box too.
I'm using the Professional version of 4.16r2.
Any suggestion will be appreciated.
Duane
    Hi Duane,
    This has been mentioned before, and a way to create non-copper areas on each
    layer would be good.  But that doesn't exist in EAGLE 4 or 5.
    A solution to your problem would be to use two overlapping polygons.  Name
    them the same and make the same rank (rank might not be necessary, can't
    remember off the top of my head) and they will flow into each other.  So if
    you make two "C" polygons they will flow together and leave you a void area
    where they don't overlap.
    Hope that helps.
    Cheers,
    James.
     James Morrison  ~~~  Stratford Digital
     email:  sales2009@eaglecentral.ca
     fax:    888.701.8097
     web:    http://www.eaglecentral.ca
     Online EAGLE Dealer for US and Canada
     EAGLE Design Experts
     EAGLE Enterprise Toolkit
