EAGLE User Chat (English) how do I reduce the amount of copper being etched away??
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 764 views
Ok stupid question!
It's been several years since using Eagle.
I have my board made up but forget how to make it so that I am not having to
etch away large amounts of copper.
I recall something about drawing a rectangle on the board...... but cant
remember the rest of the steps. I know that once it is done it makes the
gaps between this rectangle and the wires, pads and devices. I guess its
like a mask?
Any help would be great.
Glen
  • jameslittlefield
    jameslittlefield over 16 years ago in reply to autodeskguest
    I would be a little careful about doing that.   Having copper regions
    which are not tied to something may invite EMI problems.
    Jim
    none available wrote:
    Hello Glen,
    To further reduce etching, turn on Orphans when generating your polygon.
    This will fill remaining spaces.
    Mike
    "Tomas D." <mailsoc@[trinam_spam]gmail.com> wrote in message
    news:gmdaps$nmb$1@cheetah.cadsoft.de...
    Use NAME command and rename it to GND
    "Glen Higgs" <ghiggs@rogers.com> wrote in message
    news:gmd7s5$cvp$1@cheetah.cadsoft.de...
    Yes that's a good idea, just need to figure out how to make it the same
    plane as the ground- same potential?
    Glen
    autodeskguest over 16 years ago in reply to autodeskguest
    Hello Glen,
    Mike
    Glen
    Glen
    Glen
    "oliver" <o.fairhall@iinet.net.au> wrote in message
    news:gmcmvq$6r6$1@cheetah.cadsoft.de...
    Glen Higgs wrote:
    Ok thanks that did it.
    Draw a polygram around the board then hit ratsnest!
    worked great! I was trying to do it with the rectangle image
    Glen
    news:gma94i$4ac$1@cheetah.cadsoft.de...
    Ok stupid question!
    having to etch away large amounts of copper.
    like a mask?
    Glen
    Remember to make your polygon a ground plane, if you would like the
    potential benefits of additional grounding.
    Glen
    Ok stupid question!
    cant remember the rest of the steps. I know that once it is done it
    makes the gaps between this rectangle and the wires, pads and devices.
    I guess its like a mask?
    Glen
    Glen
    Ok stupid question!
    like a mask?
    Glen
    help polygon
    r
