EAGLE User Chat (English) Wish List for New Features
  • Replies 14 replies
  • Subscribers 177 subscribers
  • Views 1080 views
Hello everyone,
Now that there has been time for a lot of us to evaluate EAGLE 5, let's
compile a list of features that we'd like to see in new releases.
Tilman or another bilingual (german and english) forum participant, could
you post this on the german userchat forum in translated form?  I'd like to
get all user input, not just 1/2 like previous incarnations of this type of
interface.
I'll collect all the items, group them, and then create a poll at
eaglecentral.ca where we'll have a vote on it.  It will be bilingual.  A
poll will give CadSoft some real numbers about which items have the most
popularity.
Cheers,
James.
email:  sales2009@eaglecentral.ca
fax:    888.701.8097
web:    http://www.eaglecentral.ca
Online EAGLE Dealer for US and Canada
EAGLE Design Experts
EAGLE Enterprise Toolkit
    James Morrison wrote on Wed, 04 February 2009 22:04
    Hello everyone,
    could you post this on the german userchat forum in translated form?  I'd
    like to get all user input, not just 1/2 like previous incarnations of this
    type of interface.
    Thanks for doing that.  You don't want to read any german that I write image
    popularity.
    Let me clarify things a bit.  This is not a bash on CadSoft or EAGLE at
    all.  The reality is that everyone has a different idea of what is
    important.  The eagle.suggest.x newsgroups are a good way to capture the
    details, but they don't really indicate how many people agree with each
    suggestion.  If everyone else is like me, if I see something there I agree
    with I nod and move on typically.  CadSoft never sees that.
    The other issue is that things are split between English and German.  I'm
    sure there are many great German ideas I haven't even considered.  I'd like
    to cross pollinate this list.
    I have already gone through the eagle.support.english and extracted a
    bunch of issues for the poll.  I was hoping to extract any new ideas from
    new users or german users.
    The poll will give CadSoft info about what topics have the most resonance.
    Of course, they are free to do what they want with the info.  But the
    results may surprise them.  Or maybe not.  But in the end, it's very good
    customer feedback, all for free to CadSoft.  So I don't see the harm.
    Or maybe it flops and other people don't care.  I really like EAGLE and
    want to see it to continue to improve and there is no way to improve if we
    can't have a discussion about what improvements need to be made.  And when
    it's done, I'll post the results back to the suggest newsgroups so that
    everyone gets access to them.
    I may need some help translating along the way.  Tilman, are you game to
    help with that?
    Cheers,
    James.
    fax:    888.701.8097
    help with that?
    If it doesn't take too much time: of course.
    Tilmann
    Hello everyone,
    OK, I'll start on the english side:
    - already mentioned in German group:  hierarchy in designs.  Joerg, where
    are you image
    - Footprints to allow named copper, abnormal pad shapes, custom copper,
    - configurable colours of ratsnest wires-user can define ratsnest wire to
    be a certain colour per signal
    - control panel being able to open non-EAGLE files using OS default
    programs
    - edit local instance of footprint directly from PCB editor
    - better find functionality out of the box and configured to use (i.e. if
    it is done in ULP then already configured to assign statement by default so
    new users can access it right away)
    - store colour palette in design file if defined
    - inner layer keepouts
    - push aside router
    I'll stop there for now.  I have more on my list that I've pulled out of
    the suggest newsgroups (at least the english ones).
    Please add ideas you have had.  CadSoft won't know if you don't speak up.
    Kudos to CadSoft for the FollowMe router.  That was on my list when I
    started last week (or at least something similar).  That one caught be off
    guard and I was pleasantly surprised.
    Cheers,
    James.
    fax:    888.701.8097
    On Thu, 05 Feb 2009 21:50:11 -0500, James Morrison
    Hello everyone,
    OK: adding things as well:
    1) ability to determine if a pad can be reached by the autorouter.
    Reason:  I'm having a lot of problems trying to route 0.5mm spacing
    packages (TQFP 100 packages),
    2) ability to highlight a signal and have it stick
    Reason:  want to check signal routing for a particular signal and keep
    it highlighted while I do other things.
    3) ability in a library to add/delete pins without having to
    disconnect the pins from the schematic.
    4) ability to highlight used libraries for display
    5) ability to group select libraries for use with a single keystroke.
    Reason: helps in managing library use
    6) Ability to switch parts on a schematic from one library to another.
    7) ability to see range of "part can go here" on the board layout.
    Reason:  I'm tired of positioning a part with the "this version of
    eagle can't... etc." and not knowing where the part can actually go.
    8) ability to constrain trace angle when moved to a specific angle,
    say 0, 45, 90, etc.
    Reason:  moving one end of a trace is good, but often we'd wish to
    move traces and keep the angle alignment.
    9) ability to draw a trace and have it obey the design rules both in
    size and spacing from other traces.
    reason: this would minimize design check errors.  This takes two forms
    at least:  1) manually routing a trace would pick up the default class
    trace width and use it.  You can still change trace width, but
    manually routing things takes the default width to start.  2) when
    manually routing a trace, the trace will change color (or otherwise
    tend to "snap" to the minimum spacing from the adjacent trace).  This
    allows you to more easily arrange parallel tracks.
    10) radius command for direction changes.
    11) ability to take another board design as a reference layer and base
    other board designs on that.
    reason: this allows matching of daughterboards to a motherboard system
    or layered boards with the next board in the sequence.
    12) ability to determine the overall length of the ratsnest wires so
    that the layout can be judged for efficiency.
    13) ability to panelize print outputs regardless of the version of the
    editor.
    reason: really needed for panelize.  The restriction does not make a
    lot of sense since you can design a board only the size of your
    license.
    14) ability to print multiple layer views of the board on the same
    sheet.
    reason: needed to have the most efficient use of board/transfer paper.
    What I'd like to see is the ability to print out the silk screen layer
    set, the top set, and the bottom set on the same piece of paper.  Also
    useful for documentation.
    15) ability to memorize different layer setups and reproduce them as
    views.
    reason:  Need to switch constantly between top view layers, bottom
    view layers, and so on.  Existing layer visibility tools are useful,
    but cumbersome to use.  This is a good thing for layout purposes.
    16) switch to allow autorouting that disallows any between board layer
    connections except vias.
    Reason:  a convenience on the way that I route boards, but it would be
    a nice feature and allow me to use the autorouter a bit more easily.
    17) switch to turn off "unreachable SMD pad in layer n"  Ignore
    further messages like this would be fine.
    Reason:  I can use the autorouter to route one layer, say bottom, but
    if I have anything on the other layer, the autorouter complains
    constantly.  I can also route the top layer separately, but it'll
    complain about the bottom layer.  Not the most efficient way to do
    things, but a method that will work.
    Harvey
    are you image
    programs
    - push aside router
    Cheers,
    James.
    fax:    888.701.8097
    On Fri, 06 Feb 2009 12:19:04 -0500, Harvey White
    Hello everyone,
    say 0, 45, 90, etc.
    editor.
    license.
    sheet.
    views.
    Harvey
    are you image
    programs
    - push aside router
    Cheers,
    James.
    fax:    888.701.8097
        • Dave Pollum - YES YES YES ***
        • YES YES YES ***
    When manually routing, when I choose a routing layer (i.e. top),
    I do not want EAGLE to change it!  This is a case of EAGLE
    being too helpful, like MS Word is sometimes.  This issue comes
    up when I have a SMD part on the top layer and another SMD part
    opposite on the bottom layer. so there are 2 close airwires.  I
    have to select the correct routing layer (i.e. bottom), and then
    hide the other layer (i.e. top).
    Sometime I also have to "argue" with EAGLE when starting a route
    from an existing via.
    -Dave Pollum
    Dave Pollum wrote on Fri, 06 February 2009 19:30
    <snip>
    -Dave Pollum
    Hi Dave,
    If you start talking to your CAD package, perhaps it is time to take a bit
    of time away from the computer image
    James.
    fax:    888.701.8097
    On Fri, 06 Feb 2009 20:56:22 -0500, James Morrison
    <snip>
    -Dave Pollum
    Hi Dave,
    No, only when it answers back....
    Harvey
    James.
    fax:    888.701.8097
    Just a few issues that immediately come up my mind:
    - Urgently needed: "optional pins" in symbols - to enable us to use a
    device set even if some package variants differ in the number of
    connected pins. Currently, every difference in the symbol requires a new
    device. image I also have concrete ideas about how to implement this.
    - Swapping of "pin groups" within a device. Think of a bus transceiver
    with eigth data lines but a common enable and direction input, or a
    relay with several contact sets moved by one coil. You can't use gates
    in these cases since they could also be swapped between different
    devices - regardless of the common signals.
    - Allowing *.epf files to have /any/ name. Storing all paths below the
    epf file relative to this, all library references relative to the
    library folder, and only the rest with absolute path. This would allow
    us to use EAGLE just like any other IDE within our own project/file
    hierarchy.
    - Offer Hershey font as a forth font alternative for text.
    There surely are some more... but not right now. image
    Tilmann
    This boils down to the "feature request" that somebody inside CADSOFT
    should work on real world designs...
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    While talking about swapping:
    - Allow GATESWAP from the board. It should be possible to swap gates
    from the board, while doing the layout, by consecutively clicking any
    two pads of the gates to swap. (As in the schematic, the software will
    tell me if the swap is not possible/allowed for any reason.) I don't see
    any reason why this is prohibited, anyway.
    Tilmann
