EAGLE User Chat (English) silly question ?
  • Views 516 views
silly question ?
RICHARDBOWN
RICHARDBOWN over 17 years ago
Hi Guys
This may sound like a silly question but,
How do I produce a BOM, I found bom.ulp but nothing in the book or help
files.
I'm using ver 5.3 at the moment
many thanks
Richard
    richard.bown wrote on Fri, 06 February 2009 08:27
    files.  I'm using ver 5.3 at the moment
    There is little built into Eagle to make a BOM for you.  There are various
    ULPs that either make little more than a primitive parts list, rely on a
    external database, or use the user definable attributes available in Eagle
    5.  Then there are a lot of details about how to know when one device in a
    schematic is really a different part from another, how to deal with devices
    that don't belong on the BOM at all, seeding other spreadsheet information,
    etc.  It gets complicated fast when you really think thru the details.  For
    example, two LEDs might have the different values "Power" and "Status" but
    are the same physical part and should be on the same BOM line.  On the
    other hand, the value field can be the sole way to distinguish a 10K
    resistor from a 1K resistor.
    You might want to take a look at my BOM ULP.  It uses a bunch of attributes
    that can be defaulted in the library and overridden in the schematic as
    required.  The BOM ULP actually exports a fairly dumb parts list to a file,
    then runs a external program that determines the common parts, computes
    quantities, seeds cells with formulas for computing board cost, and writes
    the result to a tab delimited file for importing into a spreadsheet.  It
    even copies a template spreadsheet to the directory for that board.  This
    has the formatting of the various columns already set so everything looks
    right when importing the tabbed file.  All this stuff is included in my
    Eagle Tools release at http://www.embedinc.com/pic/dload.htm.  The doc file
    for program CSV_BOM describes the overall process of creating a BOM.  The
    various attributes are described in the EAGLE_ATTR doc file.
    autodeskguest over 16 years ago in reply to autodeskguest
    Hello Richard,
    There is also a part2html.ulp so you can paste the BOM into excel.  Run this
    ulp from the Board.
    Mike
    "EAGLE user" <e4opening@yahoo.com> wrote in message
    news:gmhjaa$9rs$1@cheetah.cadsoft.de...
    Richard.Bown wrote:
    Hi Guys
    files.
    many thanks
    Richard
    Select the ULP icon from the toolbar and then run the BOM ulp.
    Cheers,
    Eagle User
  • RICHARDBOWN
    RICHARDBOWN over 17 years ago in reply to autodeskguest
    EAGLE user wrote:
    Richard.Bown wrote:
    Hi Guys
    help files.
    many thanks
    Richard
    Cheers,
    Eagle User
    many thanks
    Richard.Bown wrote:
    Hi Guys
    files.
    many thanks
    Richard
    Cheers,
    Eagle User
