EAGLE User Chat (English) single sided board which side is top?
  • Subscribers 179 subscribers
  • Views 631 views
Former Member over 16 years ago
Hi there!
When working with a single sided board, is the copper side considered the
top or the back?
Glen
    "Glen Higgs" <ghiggs@rogers.com> wrote in message
    news:gmnof8$3jg$1@cheetah.cadsoft.de...
    Hi there!
    top or the back?
    Glen
    Hi Glen,
    I would prefer components on top and copper on bottom (as it will exist
    later in the real world). But it's your choice as long as you tell the pcb
    manufacturer what your intentions are.
    Carsten
    Hi Carsten
    Thanks for the info
    I etch my own boards as a hobbyist.
    Yes I put my components on the none copper side, just wasn't sure what the
    board schematic in Eagle
    considers top and bottom. So component side is top and copper side is bottom
    makes sense.
    "Carsten" <eagle38106@online.de> wrote in message
    news:gmnoto$52q$1@cheetah.cadsoft.de...
    Hi there!
    top or the back?
    Glen
    Hi Glen,
    Carsten
    autodeskguest over 16 years ago in reply to Former Member
    On Sun, 8 Feb 2009 19:47:32 -0500, "Glen Higgs" <ghiggs@rogers.com>
    wrote:
    Hi Carsten
    Thanks for the info
    makes sense.
    Looking at the names and colors of the layers, the bottom layer is in
    blue, the top layer is in red.
    You can make a single sided board with jumpers by using the top layer
    to draw straight lines, then replace these with wire jumpers.
    Alternatively, you can use a jumper as a component, but that will
    require editing the schematic.
    Harvey
    Hi there!
    top or the back?
    Glen
    Hi Glen,
    Carsten
