EAGLE User Chat (English) 2 +5V Supply
  • Subscribers 187 subscribers
  • Views 299 views
2 +5V Supply
Hello
I first had a +5V net in my schematic. Later I wanted to to change some of
thoose to a second +5V net. So i replaced it with +5V/1 in the supply2
library. If I do a netlist the new net is not there. Only the +5V net. It
also creates an ERC warning saying "SUPPLY pin +5V/1 overwritten with +5V".
Does anyone know how to solve this?
Best Regards Peter
    Obviously, you added the new supply symbol, but did not rename the net
    itself. (Type SHOW +5V in the schematic to highlight this signal.)
    Use the NAME command to rename the particular net segments to +5V/1. You
    will be prompted for renaming only the segment, all segments on the
    sheet, or all segments on all sheets. Do it segment for segment.
    Tilmann
